| | #1 |
| I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
| I thought that my pulley's set screw had come loose and it was simply rotating around the top shaft of my TLT, and thats why I wasn't getting motor power to the axles... boy was I wrong, and baffled: ![]() I thought that the belt should strip before the pulley disintegrates! Thats an HPI Nitro belt, and it has NO damage to it, but the pulley is completely destroyed. Where there are no teeth it is super smooth. Turns out one of my bearings seized which was intermitently seizing the topshaft/pulley... but even with that, I can't believe the pulley disintegrated the way it did! |
| Sponsored Links | |
| | #2 |
| I just found a 16t aluminum tamiya pulley on tower. Most of the HPI ones are on way pulleys... Finding all the weak parts of this truck is driving me nuts! |
| | #3 |
| Newbie Join Date: Aug 2004
| crap dude that's nuts! that's really something! it doesn't even look like the belt frayed! what motor are you running?! size? # tooth pinion? that's just.....baffling. |
| | #4 |
| I am using a matrix 27 turn motor (stock 540), with a 12t pinion and 90t spur. |
| | #5 |
| Quarry Creeper Join Date: May 2004
| thats nuts. by the way check your pms |
| Thread Tools | |
| Display Modes | |
