10-04-2008, 10:38 AM | #1 |
Pebble Pounder Join Date: Nov 2005 Location: united kingdom
| copperhead
decided to do a mock build on my copperhead to get the link sizes right so i can order some ti ones. the axles:- front includes bearings rc4wd alloy knuckles fat rock c's straight through shafts and twinset servo mount rear includes bearings alloy rear lockouts and twinset rear truss shocks are alloy traxxas tranny is rc4wd r2d traxxas stampede drive shafts with metal yokes. wheels are junfac beadlocks with alloy outer rings and losi claws with memory foams. and finally the chassis is a copperhead also from rc4wd. no electrics in it yet but will be using mamba max esc with holmes hobbies revolver black brushless motor and 2400 3cell lipo's. any hints or tips will be considered. i am quite happy with the way it looks but things may change thanks for looking |
10-04-2008, 01:07 PM | #2 |
RCC Addict Join Date: Jun 2008 Location: Wasilla
LOOKS GOOD! tip: move the upper shocks closer to the hoops you will bend those things you have holding them out off right away. my buddy runs a copperhead. - tre |
10-04-2008, 07:03 PM | #3 |
RCC Addict Join Date: Nov 2005 Location: Kansas
Impressive! I like the way they designed the chassis to mount the servo for the dig... I wonder if there would be any advantage to having it mounted in the chassis as opposed to mounting it on the transmission... (like possibly less resistance, less stress, etc.) overall nice rig! throw those electronics in there and get to crawlin! |
10-04-2008, 10:47 PM | #4 |
Pebble Pounder Join Date: Jul 2008 Location: kelowna
Although the integrated servo mount is pretty slick and werks really well, if you use the servo mount plate for the r2d instead of the lexan inspection cover it does get your servo lower. I never liked the wrap around skid plate, Aluminum is not the slipperiest material. Something to think about. Make sure you loctite the 4 screws that hold the bottom plate in the chassis as they are notorious for coming loose.. |
10-08-2008, 07:17 PM | #5 |
Rock Crawler Join Date: Sep 2004 Location: South Orange County
| 2 tips #1 for your tie rod and drag link end links on top of your knuckles this will give you more clearance under your axle. if you have any doubts on steering setup, you should read this tech article. It is very informative and contains good pictures of what I am talking about. http://www.rccrawler.com/strongsteering.html #2 The screws that you used to mount the shock and lower link. you have screws in backwards. You should have then face of the screw on the front of the axle and if there is too much thread left over get shorter screws or trim down the ones you got. Doing this modification will give you a tighter turning radius because the knuckles wont get blocked by the screws. You can see what I am talking about very clearly in this picture. they are the 2 vertical screws on the far left and the 2 vertical screws on the far right http://www.rccrawler.com/articles/st...ing/steer1.jpg Last edited by iwantoffroad; 10-08-2008 at 07:23 PM. |
10-08-2008, 07:25 PM | #6 |
Thats not a Copperhead.
10-08-2008, 08:32 PM | #7 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
| It's not THE Copperhead, but it is a copperhead from rc4wd.... http://rc4wdstore.com/product_info.php?products_id=727 |
10-11-2008, 01:13 PM | #8 |
thanks for the tips fella as i said it is just mocked up for now and will do these small mods when i get down to the real build which should be happening soon. will post more pics when she is built |
10-12-2008, 02:23 AM | #9 |
10-12-2008, 07:13 AM | #10 |
thanks for that i was starting to doubt myself |
10-15-2008, 07:15 PM | #11 |
are you all done with mock up yet lets get this finished |
10-15-2008, 10:12 PM | #12 | |
Pebble Pounder Join Date: May 2008 Location: Tyler, Texas
10-16-2008, 01:57 PM | #13 |
cheers fella got my links now so the build should start soon thanks again for the tips. mexiCAN do you have a few more pics of yours so i can see if i can get any ideas from ya if you dont mind cheers |
10-17-2008, 12:58 AM | #14 |
I will see if I can dig some more up... Its really very simple, I just traced out the tranny pan and cut it out of hdpe (cutting board) and then later re-did it with acetal, and made some simple side plates out of lexan, it gives you much more ground clarence as well as narrows up the bottom end by at least 1" total if not more. if I were to forget to find pics, just pm me and remind me good luck with the build, looks like your off to a good start
