08-18-2005, 06:30 PM | #1 |
Rock Stacker Join Date: Apr 2005 Location: Hebron
| problems with blackfoot axles
has anyone experienced problems with the fit of blackfoot stub axles into a tlt axle when i screw the outer hub assembly to the tlt axle the blackfoot stub axle bottoms out on the tlt inner axles and becomes very hard to rotate but if i take them hub back off it rotates freely i can also see on the tlt inner axle where the blackfoot stub axles have been digging into them has anyone had this problem and know a fix for it ??? |
08-18-2005, 08:02 PM | #2 |
Gold Star Baby Momma! Join Date: Feb 2004 Location: Maumelle, Ar
just installed mine and I love them, I do remember someone was talking about getting more steering by clearancing the stub axle a little bit. If yours is binding you might try that mod. |
08-18-2005, 08:14 PM | #3 |
Rock Crawler Join Date: Jul 2004 Location: OC, Oregon
well the blackfoot stubs are longer where the dogbone hooks in (behind the knuckle part, what ever that part of the stub is called) i cut mine down to stock tlt lenght. Just whip out the dremel and cut away |
08-19-2005, 01:19 AM | #4 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
Yeah, grind them down something like this I used a table grinder |
08-19-2005, 12:12 PM | #5 |
RCC Addict Join Date: Dec 2004 Location: HELL.....
i was looking at widening my tlt and was deciding between the blackfoot axles ot the inet wheel wideners. other than cost whats the difference? how much do u gain from the blackfoot axles? are they wobbly? |
08-19-2005, 01:41 PM | #6 |
Quarry Creeper Join Date: May 2005 Location: Auburn
bugger glitch lost all the typing!! OK here I go again What I did was used a endmill in my drill press ( this allowed me to keep the cut the same over all the parts) After that I re chamfered the insides with a countersink bit. I did this to elimanate any sharp edges that could gouge the axle dog. As well if you grind them down dont over heat the metal, if you do douce it in cold water to keep the temper. There is the chance you will weaken the metal in that area. ( hell most of you all prolly know this anyhoo, better safe than sorry right??) Other than that my only complaint on the axles is the threaded bit is too short for HPI rims. The stock lock nuts wont engage the nylon threads. I ended up using traxxas slipper locknuts. ( thinner profile) oh yeah spacers some go through the hastle to cut em but one of the wheel bushings and a canti bushing are near perfect to space things out the canti bushing rides right on the inner race of the BBs without hitting the outer parts! Its hack but heh cheap *** and a lazy solution! |
08-19-2005, 02:39 PM | #7 |
Rock Crawler Join Date: Jan 2005 Location: Bethlehem, GA
Yes, they have to be grinded down to stock dog bone cup depth. Then you will have to space the wheel adapter out like the pic above. I used the cantilever bushing from the cantilever arms that I removed to space out the adpater. They fit the axle perfectly and they are a bushing so if they spin they won't wear as much as a piece of plastic would. |
08-20-2005, 05:53 PM | #8 |
well i havn't cut mine down yet but i do not believe that is the problem reason i say that is because when i try to screw down the 2 screws that hold and allow the hub carrier to move is very hard to tighten down it feels like the screw cross threads in the plastic but they don't if you had read my original post i believe that the blackfoot axles are not sitting far enough inside the hub carrier which is cause the assembly to bind up and become very hard to turn i did forget to mention that when i have the axle assembled with the bf axles it is difficult to turn the tranny side drive shaft when i looked closer at the bf axle there is a lip that is located in between the shaft and the axle carrier i think if i remove this lip it will allow the axle to seat farther into the hub carrier and eliminate the bind |
08-20-2005, 06:09 PM | #9 | |
08-20-2005, 08:06 PM | #10 |
Yeah I think you got the steering knuckles backwards or upside down. The blackfoot axles shoulndt bind, say for the rear with fixed steering. If the axle is shoved so far against the axle bones there is something getting hung up between the blackfoot cup and the bearings. There is a slight rake to the knuckles. ones labled c1 go on the left c2 on the right. Its the only thing I can think of thats the issue. PICs might help us see what the issue is. As well that small lip or bump out is to engage the bearing race DONT mill it down. That will cause the face of the cup to drag against the bearings face destroying the bearing and prolly the BF axle. |
08-21-2005, 09:15 AM | #11 | |
that was it i did not know that the hub carriers had a different shape with the top and bottom nubs thanks for the help | |
