12-21-2008, 08:50 PM | #1 |
Newbie Join Date: Dec 2008 Location: alpine ca
| What gearing
I am using a stock stampede tranny all locked up with a stock spur gear and stock tlt axles locked up with a novak rooster crawler speed control and 55 turn motor.I have tried 12,14,18 pinion and it just doesnt want to crawl well.What should i be using.Im frustrated as hell any help would be great.
12-22-2008, 01:29 PM | #2 | |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
12-22-2008, 02:57 PM | #3 |
Rock Crawler Join Date: Oct 2006 Location: Fernley
I tend to run anywhere from a 78t to 87t spur with 16t to 18t pinion on 55t motors in my pede's and they all work well with that setup. I am currently running 2 pede's with 84 spur and 16 pinion. Make sure your gear mesh isn't to tight.
12-22-2008, 08:46 PM | #4 |
What does the spur change from higher to lower i believe the stock is a 87 tooth spur.Would i be better to go lower with a 16 tooth pinion
12-22-2008, 09:54 PM | #5 |
It depends on whether you want more wheel speed or more torque. A higher number spur will create more torque, just like a lower number pinion will, and vice-versa. I just used the 84 because I already had it, and had some pinions to match. For some reason I have found that not all 48 pitch gears are the same. For example; Tamiya gears do not mesh with axial or traxxas gears.
01-06-2009, 01:01 AM | #6 |
Newbie Join Date: Nov 2007 Location: Naperville
im running 16/87 with a 65t and it crawls great a little fast but a lotta tourqe
