| | #1 |
| Rock Stacker Join Date: Jun 2004 Location: Hillsboro, OR
| Many of you may have already seen this on some of the other TLT sites, but I thought I'd post it up here if some of you don't go anywhere else for information on the TLT. Since my truck is only used as a rockcrawler, I wanted the most axle clearance as possible. With this in mind it means moving your links up from the bottom of the axle to give you more clearance. I moved the top link mounting brackets to the side of the axle, and the bottom link mounting brackets to the top of the axle. The new side mounts use the two outside holes that are used to hold the axle together. I had to dremel a little bit of the material off of the axle, but the end result works great and looks factory. This also gave me a new mounting location for my shocks so both links and the shocks still have thier own mounting holes. |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Feb 2004 Location: Michigan
| thanks for the post! I'm going to get a tlt soon and this is the only site I know of for info. great mod! I keep hearing about the center diff stripping is that true? |
| | #3 |
| I didn't have any major problems with my differential when I had the stock transmission in my truck. I ran two screws through it and JB welded it together so it was never coming apart. With the TLT you don't ever need a center differential and anybody that owns one should lock it up when the build it. The rest of the transmission held up fairly well to crawling. I would suggest you put a belt tensioner on it (search this site for how to do that). With the belt tensioner and a locked center differential it's a fairly tough transmission. I however wanted traxxas sliders on my truck so I could get more center clearance. So I made a custom chassis out of Delrin plastic and droped a Stampede tranny in my truck. |
| | #4 |
| Quarry Creeper Join Date: Jun 2004 Location: Fairmont
| Wookie, How did you get the sliders to work with the TLT axles? Did you have to change the outdrives or modify them in some way? Let me know. I want to do that to my TLT. Thanks Clark |
| | #5 |
| First of all I installed a Stampede tranny, though there are ways you can use your stock tranny if you wanted to. To get the sliders to fit the axles, all I did was remove the stock drive cup, put a metal Traxxas Stampede U-Joint on the axle and tighten it down. It's a perfect fit and really easy to do. |
| | #6 |
| Pebble Pounder ![]() Join Date: Jul 2004 Location: Quakertown PA
| Great info Wookie. I've been scratchin my head on how to change the locations, this way is easy and clean. What other sites are there for TLT info? |
| | #7 |
| Other sites for TLT information are: www.one18th.com www.yourmicro.com One18th has some good information and is more active than your micro. |
| | #8 |
| Wookie, Aren't the cups part of the shaft that goes into the axle? How did you just remove the cup? I can't imagine. Fill me in on the info. Thanks Clark |
| | #9 |
| On my TLT the drive cups are attached to the axle with a allen head set screw. If you loosen that scew the drive cup pulls off of the axle. With the stock transmission you will need to replace the differential with a Traxxas 4-Tech differential, make your own custom spool or drop a Traxxas transmission in. I'll try and take some pictures of my axle set up tonight when I get home. |
| | #10 |
| Thanks for the info. Clark |
| Thread Tools | |
| Display Modes | |
