Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: My ever growing TLT-10
Old 08-26-2004, 11:37 PM   #1
Default My ever growing TLT-10
Just thought I'd throw these up here.
I picked up a new body, T-Maxx Jeep CJ8, yesterday. When I got it home I noticed my wheelbase was just a little short to really give a scale look (11.5" wheelbase). So what do you do when you truck is just a little short? Extend it
So my TLT now hase a wheelbase of 12.75" and just a hair under 4" of center clearance.
I had to fabricate some new sliders, so I used brass tubing that fit snugly over the Stampede sliders, then used 4/40 screws to run directly through the sliders to keep them from slipping. I then dremeled the left over pins down so they were nearly flush with the brass tube sidewall.
When these sliders die, I'll probably switch to E-Maxx sliders or figure out a better way to make longer Stampede sliders (they are nearly double the length of stock).
I'll have pictures with the body on by tomorrow night. My dremel ran out of juice so the battery is charging right now.
Wookie is offline   Reply With Quote
Old 08-27-2004, 12:12 AM   #2
Default Re: My ever growing TLT-10
Right on!! I am doing a stretched tlt too. Mounting up a TJ body, I'm at 12.75 right now but buy tomarrow I see 13"s in the end. When I put the traxxes tranny in I lined up the spur with the stock hole and got to cut of alittle over a 1/2" off the bottom. I see 4 to 4.5"s of clearence in the end, I had to extend shafts too.
DUDE is offline   Reply With Quote
Old 08-27-2004, 12:42 AM   #3
Here are some body shots. My camera doesnt' do the color justice. I'll take a few pics tomorrow in the sunlight which will look a lot better. This weekend when it hits the rocks I will have much better pics of it in action.
The body is about 1/2" higher than I wanted it, but overall it's OK.
Old 08-27-2004, 12:57 AM   #4
What did you do for sway bars?? I know it is going to be an issue with my set up. The way I have it set up it needs them to work like predicted.
Old 08-27-2004, 01:20 AM   #5
Are you talking about the links or actual sway bars?
I'm not using any sway bars, but the links are all T-Maxx turnbuckles. I have 106mm on the bottom and 116mm on the top. I relocated my link brackets which is why the top links are longer.
My chassis is also 3/4" longer than stock, which gives a little extra length.
Old 08-27-2004, 01:29 AM   #6
I thought I seen a sway bar in one pic, my bad. It was the servo wires or something. :? I am going to try mine with out first of course than I will see.
I like your CJ8 body. I didn't think it would fit. I see it is a good fit. Let us all know how stable your rig is. The trouble I have been having is staying somewhat scale and have it work good and stay low at overall highth.
Old 08-28-2004, 06:35 PM   #7
Dude,
You should pick up some wheel wideners from www.inetrc.com they will add 1.5" to the width of your truck and make it much more stable at longer lengths. The run about $40.00 for a set of 4.
Here are a few better pictures of my truck.
Old 08-28-2004, 06:41 PM   #8
Thats awesome! I can't wait to see pics of it tommorow in action... Once I am out of debt, I'm going to get my tlt like yours
KidWithAcrayon is offline   Reply With Quote
Old 08-28-2004, 07:34 PM   #9
This guy has maxx size mashers on his tlt...
http://www.ultimaterc.com/gallery/di....php?pos=-1613
Old 08-28-2004, 08:16 PM   #10
RocJoc's Avatar
Location: crawlin with out the bullshit of someone else's rules
ALSOME looking crawler like the paint on the body but it should be
a rubicon body just my 2 cents.
RocJoc is offline   Reply With Quote
Old 08-30-2004, 09:01 PM   #11
Here are some updated pictures with my new wheels and tires. I'm waiting for the hex adapters to be re-stocked, but for now I can at least check out the look.
Old 08-30-2004, 09:57 PM   #12
Originally Posted by Wookie
Dude,
I am thinking about it, The way it is right now I am at 35* stable side hill. I would like to see 40*+ if possible. The rig I am doing is for fun and scale.
The buggy in planning on the other hand................
Old 08-30-2004, 11:12 PM   #13
Hay wookie, here is a fat tire for ya. Just that it takes 2 tires to make one. Cut these duals down the middle two groove lines and put on a standard 2.2 rim and you would have a killer tire pattern that would work awsome on over size foams.
Old 09-03-2004, 09:37 PM   #14
Hey how are you guys getting so much ground clearens? Bigger tires and what else?
TheNewbie is offline   Reply With Quote
Old 09-04-2004, 10:59 AM   #15
Bigger tires is the only way to get more ground clearence under the axles but for under the chassis you need to extend the links (wookie uses traxxas linkages i think, you can also make your own out of 4-40 all thread and break line) and get some longer shocks. But i would get some bigger tires before you do the lift because with the lift you have to get a new dogbone or go the pede tranny way. Plus all the ground clearence under the chassis will be useless if you get your axles hung up on every little rock.
pedesrule is offline   Reply With Quote
Old 09-27-2004, 10:02 PM   #16
TRD
WOOKIE
THANKS FOR THE TIRES THAY ARE GREAT I JUST GEARED DOWNAND JB WILD THE FROUNT ,REAR, CENTER DIFFS AND IT IS SWEET I ALMOST SOLD IT . I FOUND A TXT BUT I PUT THE TIRES ON AND I LOVED IT SO IM KEEPING BOTH OF THEM HEHEHEHE!!! THE WIFE IS PISSED WELL THANKS
TRD
PS I WAS IN SHERWOOD WHEN YOU SENT THEM OH WELL NEXT TIME !
TRD is offline   Reply With Quote
Old 09-27-2004, 10:13 PM   #17
bendforthebone
me like
badtodabone is offline   Reply With Quote
Old 09-27-2004, 10:13 PM   #18
bendforthebone
oh yeah how did you do that with your tires? tech article maybe?
Old 09-28-2004, 10:40 AM   #19
TRD,
Glad you like the tires and they helped you keep your TLT :P , Just tell the wife you needed a back up truck, just in case
badtothebone,
How did I do what with the tires? I've done lots to mine just depends on what you are asking for.
Old 09-28-2004, 12:07 PM   #20
Hey wookie, I had to use your lower link mounting idea. I really like the fact it gives you almost no hang up spots under the axle. It also eliminated the axle turn in ( wheels coming together when flexed side to side) and stretched the wheelbase a little bit. Great job with that idea!
Plays_with_Toys is offline   Reply With Quote
