10-06-2005, 04:57 PM | #1 |
Rock Crawler Join Date: Feb 2005 Location: stafford springs
| My RBX TLT.......
Still needs some tweaking. I want a longer WB it's only 11" right now and I need to get the chassis lower to the ground Specs are... RBX laydown chassis Pede tranny locked Integy lathe motor w/12T pinion Pede driveshafts BBY 1/4" links BBY link mounts Proline Moabs that need the foams to be cut! Ofna 2.2 wheels narrowed just a bit! Here are some pics remember it's not done yet and needs tweaking so don't make fun of me too bad! Any suggestions would be great! |
10-06-2005, 05:42 PM | #2 |
Rock Crawler Join Date: Aug 2004 Location: Concord Ca
When you put in the longer Dubro 4-40 Heavy duty ball links the ride height will drop and the WB will go out to 12.5 I can only see some of the pictures.
10-06-2005, 05:49 PM | #3 |
Quarry Creeper Join Date: Feb 2004
WHen Ya gonna come over and Crawl? Im In Willington .
10-06-2005, 06:00 PM | #4 |
Moderator Join Date: Jan 2004 Location: chicago
looks good. but you may need them longer ball-ends. if you want to beef up your steering these drop right in to replace the center link. http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXDDY3 what i do is keep the stocker knuckle to servo link and just put a traxxas ball end on the one side going to the knuckle. havent had any problems with bending it. (yet) |
10-06-2005, 06:02 PM | #5 |
ok, disregard my reply. for some wierd reason everytime i refresh this page i see different pics...
10-06-2005, 06:17 PM | #6 |
Quarry Creeper Join Date: Sep 2005 Location: Sydney, Australia
the pics dont work prperly
10-06-2005, 06:48 PM | #7 |
Quarry Creeper Join Date: Jan 2005 Location: Westchester
Pics work fine for me. Ride height is too tall, wheelbase may be a little short. All depends on how it performs. |
10-06-2005, 11:21 PM | #8 |
I'm going to order some of the dubro ends from you Randy. Thanks for the tip Hoopty! Les (bidbadwhitey) Hopefully soon, when is the next time you plan on crawling? |
10-06-2005, 11:33 PM | #9 |
10-06-2005, 11:46 PM | #10 |
Pebble Pounder Join Date: Apr 2004 Location: Aurora
try a softer spring on the shocks, they look waaaaaaay to stiff. that will give you both a LCG and a longer wheelbase.
10-06-2005, 11:56 PM | #11 | |
10-07-2005, 12:00 AM | #12 | |
10-07-2005, 12:03 AM | #13 |
um try looking on tower, or perhaps try a lower weight shock oil.
10-07-2005, 12:10 AM | #14 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
I used these then drilled them to 1/8" and tapped them all to 4mm. 4-40 threads will bend. From what i've seen. Pics no work for me either
10-07-2005, 12:11 AM | #15 | |
10-07-2005, 10:01 AM | #16 | |
RCKJeep it is rare that I bend the 4-40 Black screws, I use them on the biger 16.5 inch TXT and with the LST, MGT and Big Moabs they work fine. On the smaller TLT with 2.2 tires no problem. I think the only time Iever had any bending was when we ran the Jumbo Kongs! | |
10-07-2005, 10:05 AM | #17 | |
I wanna be Dave Join Date: Jan 2004
10-07-2005, 10:20 AM | #18 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
I would, 1. Lower the body 2. Make the rear links about 1" longer then the front for a 60/40 setup 3. Make your center clearance at about 2 3/4" or 3" and your wheel base at around 12.5" 4. Cut the centers out of your foams and use them, then add lead shot to your front tires. 5. Shave your diffs. 6. Move your steering links above the knuckle mounts. 7. Move your rear steer lock out much higher. |
10-07-2005, 10:22 AM | #19 | |
9. Grab your axles 10. Look behind you as Badger pounds your ***. | |
10-07-2005, 10:36 AM | #20 | |
Quarry Creeper Join Date: Sep 2005 Location: Lufkin
