Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: bevel gear, ring gear mesh
Old 05-08-2009, 01:34 AM   #1
Default bevel gear, ring gear mesh
i was wondering if you have to shim the bevel gear in any way, cause right now it is slipping, or maybe i stripped out the gear, i havent checked it out yet but im still curious about shimming it?
rocksteadily is offline   Reply With Quote
Old 05-08-2009, 01:49 AM   #2
Yes you can and should shim both the pinion and ring gear in the TLT axles.
themerc64 is offline   Reply With Quote
Old 05-08-2009, 03:47 AM   #3
Yup like posted above it's a good idea to shim the ring and pinion gears for a little tighter mesh.
Xtant3150c is offline   Reply With Quote
Old 05-08-2009, 03:50 AM   #4
MWRCA'er
Mnster's Avatar
If it's slipping there is a very good chance it is already toast. I usually slide 1 Traxxas fiber washer under the pinion on my axles to get the perfect shimage.
Traxxas #1985
http://www3.towerhobbies.com/cgi-bin...&I=LXJJ88&P=ML
Mnster is offline   Reply With Quote
Old 05-08-2009, 08:27 PM   #5
Default shim? why?
I have been running my axles for 1 1/2 years. never had to shim them. I run the novak Goat system on my rig. I drive it HARD!! Never had any issues with them slipping or stripping.
Don't get me wrong Not saying you don't need to just sharing my experience.
scrounge is offline   Reply With Quote
Old 05-09-2009, 12:04 AM   #6
i just put in a nylon washer, it seems to have a good snug mesh, but ill see how it lasts when i go play again
