10-22-2005, 07:09 PM | #1 |
Newbie Join Date: Sep 2005 Location: Albany
| My first try at a TLT
Ok, so after soaking up as much info from here as possible and then trying some of my own ideas (kinda) here's what I put together. I do have some issues with it, so comments/critisizm is more then welcome (just keep in mind this is just my first) http://i24.photobucket.com/albums/c2...9/000_0211.jpg http://i24.photobucket.com/albums/c2...9/000_0210.jpg http://i24.photobucket.com/albums/c2...9/000_0209.jpg http://i24.photobucket.com/albums/c2...9/000_0208.jpg BTW the issues are: the chassis twists bad when driving when I go forward, it pulls the left rear down, and when I reverse the front right gets pulled down. Any ideas aer definately welcome. Last edited by lukej6009; 10-22-2005 at 07:30 PM. |
10-22-2005, 07:40 PM | #2 |
Newbie Join Date: Oct 2005 Location: stl
what kinda motor are you running? and is the center diff. locked? what transmission are u useing? and is it when you take off fast? mine does the same think when i take off fast. imk
10-22-2005, 09:43 PM | #3 |
Rock Crawler Join Date: May 2005 Location: omaha
Okay, for starters, good beginning. Here are a couple things to look at. 1. Either swith to MAXX sliders or get the metal Traxxas yokes for the axles. You will destroy the plastic ones in no time. 2. The torqueing can be reduced greatly buy lowering your CG and standing the shocks up. 3. Try getting your hands on a set of MAXX shocks. You can find them almost anywhere, cheap, and you can change the springs. In other words, get rid of the TLT stock shocks. The correct angle on the shocks, slightly stiffer springs on the new shocks, and getting those electronics lower will help get rid of the twisting. Get some pics to us after you get the changes done |
10-22-2005, 10:19 PM | #4 |
Quarry Creeper Join Date: Sep 2005 Location: Sydney, Australia
it twist to the left cause the shock are too soft. do what rd40 said and get some maxx shocks. i wouldnt go metal yet unless you brake the plastic ones more then 2 times. |
10-23-2005, 11:52 AM | #5 | |
Rock Crawler Join Date: Mar 2005 Location: Dude on my dirt bike in SoCal!!!
Suggestions on torque twist. Move your upper link mounts on your chassis down toward the lower links... I have mine at the same spot good start tho... keep it up | |
10-23-2005, 02:09 PM | #6 |
Thanks for all the replies, I don't know what the motor is, it isnt labeled I was just assuming its the stock pede motor, since thats where all the electronics/tranny came from (found a killer deal on a used one). All the diff's are locked, and it doesn't matter how fast I take off it always toques. I did just get my maxx shocks in the mail, same light blue springs as nd4spdbh. I'll try moving the upper links down and mounting the maxx shocks a little different. Also right now I have about 4" clearance in the center, I'll try getting that closer to 3". But I wanna keep my 11 1/2" wheelbase cause it fits that body real nice. Thanks again, I'll post pics soon with the updates. |
10-23-2005, 07:01 PM | #7 |
lukej6009, use the plastic ones if you like, but take it from a guy that has to this point built 6 different shafties. I have also ran MANY Traxxas vehicles over the past decade with the plastic yokes, (boats, trucks, touring cars, and crawlers) they will fail. Think of the load those yokes are under. I have split the plastic ones one a stock Rustler jumping curbs. On my Nitro 4-TEC I was going through at least one per race before I switched to the metal ones. My boat would kill one every time the boat jumped a wave. It has nothing to do with being a lazy ***. It has to do with building a truck you can take out in the middle of no where and not worrying about breaking. |
10-23-2005, 08:24 PM | #8 |
Yeah, I think one of them has a minor split already from the abuse in the stampede, I'm just gonna run them till they break then prolly go metal. But for now no need to replace them.
10-23-2005, 08:32 PM | #9 | |
Pebble Pounder Join Date: Aug 2005 Location: Stockdale, PA
10-23-2005, 08:57 PM | #10 |
HAHA, I made the male half of the slider out of aliminum. No more twisting. You can kind of see the male hlf of the slider on the rear is made of alum. I will get a better shot of them tonight |
10-24-2005, 08:02 AM | #11 |
Ok, so made a couple changes with the suggestions and here's what I came up with. http://i24.photobucket.com/albums/c2...9/000_0218.jpg http://i24.photobucket.com/albums/c2...9/000_0217.jpg If it wasn't for the shocks being so stiff, this link setup is capable of much more articulation then before. As of right now I lost some of my articulation, the shocks don't come anywhere near bottoming out. Any suggestions on how to get some of that articulation back? Forgot to mention, now it's down do about 3 1/4" center clearance and 12" wheelbase. Last edited by lukej6009; 10-24-2005 at 08:11 AM. |
10-24-2005, 11:27 AM | #12 | |
10-24-2005, 11:29 AM | #13 | |
I wanna be Dave Join Date: Jan 2004
10-24-2005, 12:02 PM | #14 |
I love you too Dirk |
10-24-2005, 12:10 PM | #15 | |
10-25-2005, 09:12 PM | #16 |
I run the Losi red 2.5 springs on my TLT, works great for me. It get good articulation but rebounds nicely.
10-26-2005, 12:19 PM | #17 |
Well I got the shocks repositioned and now it articulates much better. I'll prolly just leave the light blue ones on there. Thanks for all the help.
