12-05-2005, 06:31 AM | #1 |
Pebble Pounder Join Date: Aug 2004 Location: Vienna
| Pede tranny vs. Stealth tranny
Are there any big advantages that would make one tranny a better choice? Price, size, less modification?
12-05-2005, 10:51 AM | #2 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
Well I think the main reason for using pede's is the driveshafts. Most other trannies use a cup and dog bone so it's mainly ease of use. I think. But some Losi trannies use driveshafts as well. But I"m not sure which ones.
12-05-2005, 11:29 AM | #3 |
Size and weight is another huge factor, the pede trannys seem to be larger and heavier than the losi's and ae's.
12-05-2005, 11:40 AM | #4 | |
Newbie Join Date: Oct 2005 Location: Portland
My two cents, Travis | |
12-05-2005, 11:49 AM | #5 |
any recommendations on which to buy? price about the same? performance about the same?
12-05-2005, 11:52 AM | #6 |
Quarry Creeper Join Date: Jan 2005 Location: Upstate NY
If you're willing to do some modding the stealth tranny is a gem. Its lighter and in my opinion stronger than the pede. I've had both in many of the small scales I've built, but i've always liked the stealth better. Plus you can usually find them on the Bay for much cheaper.
12-05-2005, 11:58 AM | #7 | |
12-05-2005, 02:00 PM | #8 |
Quarry Creeper Join Date: Jan 2005 Location: Westchester
Well, I posted this how-to on this forum awhile ago, but i dont know where it is so here it is on one of my regular forums. http://ripper7racing.com/forums/inde...showtopic=4550 You need to lock the differential too. Old school JB Weld(not the quick drying stuff) through the ball diff will do it. And you need to lock the slipper( CA glue works). I've been running mine in everything. Once you get Maxx drivlines on there, your gaurenteed a tough tranny. |
12-05-2005, 02:33 PM | #9 |
RCC Addict Join Date: Jun 2004 Location: SERCRC
| I drilled out the yokes on my Revo shafts, slide 'em over the AE Stealth drive cups. I haven't locked up the slipper. Figured a little slip would save drivetrain parts. |
12-05-2005, 05:46 PM | #10 |
Thats exactly what i did aswell.
12-05-2005, 07:06 PM | #11 |
From the picture in the link, it looks like the yoke is just slid over the outdrive from the tranny. I see the grub pin going through the outdrive slot, but can't the yoke actually pull off the outdrive? It looks like the outdrive needs cross-drilled to accept the grub pin. Or am I missing something?
12-05-2005, 08:14 PM | #12 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
On mine, the maxx yoke pin is larger than the slot, so you still gotta enlarge it. Personally I love the AE, but I'm going back to the pede on my new Bender chassied TLT. Here's some pics. AE on the left, Pede on the right. see the size diff The middle one is from another Tarxxas ST, IDK the name though. Same internals as the pede. To lock the diff, I used only 3 diff balls spaced evenly around the diif gear, just for spacing. Then hot glue, epoxy, or JB weld the two out drives & diff gear together. I also did not use the thrust bearings & spring that goes in the out drive, Just locked it down w/red locktite as tight as I could. Hope this helps |
12-05-2005, 08:16 PM | #13 |
Quarry Creeper Join Date: Dec 2004
I'm using a stealth tranny in my new tuber. -JB welded the diff -locked the spur by drilling through the backplate of the slipper and threading 3mm screws all the way through -Designed some "yoke adpaters" for the pede yokes/shafts. Had Bill over at RCAlloys make my design come to life. Thanks Bill! locked spur yoke adapters see how it holds up when I finish the tuber |
12-06-2005, 08:51 AM | #14 |
does anyone know a source (besides ebay) to buy a complete AE stealth or Team Losi XXX tranny? I do remember a post that someone has a source to buy a Pede tranny as a kit. But I would prefer a XXX or AE. |
12-06-2005, 08:39 PM | #15 |
Quarry Creeper Join Date: Apr 2005 Location: Malaysia
Wow! Is that drive-cup mild steel or some kind of aluminium alloy? Was it difficult to drill through? Did you use a drill-press? I once tried to drill through stainless steel and I asked a question about that in the tools section sometime back but I still haven't really found a good way to do that. I gave up on that silly idea. |
12-06-2005, 08:41 PM | #16 |
Oh and one more question. Did you need a special kind of screw tap to tap those threads? From the pics it really looks like a very hard material.
12-06-2005, 10:30 PM | #17 |
You can buy a complete AE Stealth tranny from AE, cost you about $90. Comes complete.
12-18-2005, 08:44 PM | #18 |
sicj, how'd you drill those output shafts? |
12-18-2005, 10:12 PM | #19 |
I didn't..... had someone else do it.
