10-07-2004, 04:14 PM | #1 |
Quarry Creeper Join Date: Jul 2004 Location: Texas!
| My bigger and better, LB TLT-10 crawler (56K WARNING)
I fininally got it all done almost. I just need to lock the center diff. Specs: 4.4' center clearnace 2.2' axle clearance 13.75' wheelbase 19' long Custom made dogbones. 1/8' rod and drill bits You can see the driveshafts somewhat. They were very hard to make. With about a centimeter left under the chassis. Gotta have a pretty background right?? Winch, still needs a little work. |
10-07-2004, 06:42 PM | #2 |
I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
| Re: My bigger and better, LB TLT-10 crawler (56K WARNING)
Looks good. What kind of tires are those? They don't look like mashers, and look like a harder rubber compound. What body have you decided to use? I like the winch too. Seems like its the thing to do now. Guess new rules will have to be made for "chord guidance" because its only a matter of time before side and rear winches are implemented. |
10-07-2004, 06:49 PM | #3 |
Rock Crawler Join Date: Jul 2004 Location: OC, Oregon
I think those are clod tires......... :o
10-07-2004, 07:09 PM | #4 |
Lol.. terrible one was correct. They are cut-n-shut clod tires. Just the right size I think. I am going to get a jeep body or chevy body soon. I need to make some body mounts. I will update the pics when I get some body mounts. I will also add some action pics once I get the center diff. locked. |
10-07-2004, 08:03 PM | #5 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
Nice I just got a set of clod tires myself, now mine has almost the same exact measurements as yours. How wide is your truck with tires? Mine is 9.5 in, which seems way too small |
10-07-2004, 08:06 PM | #6 |
I have the wheel wideners and clod hubs, so it is 12 inches to 12 1/4 (counting the lugs) thanks for the complements. Do you have any pics of ur tlt custom?? If so, u should post em up. I think I remeber seeing pics of them on ultimant rc (or w/e that is) forum. |
10-07-2004, 08:16 PM | #7 |
Quarry Creeper Join Date: Feb 2004
Get a Rubicon Body It will Fit perfect and Look scale.I run Cut and narrowed Clod tires on mine With a cut Rubicon Body and a tube Chassied TLT .looks Awesome and Crawls great.
10-07-2004, 08:23 PM | #8 |
Alright. I propbley will buy it soon. I dont have much money, so i will order it in about a week or two. I will just run my maxx body on it for now.
10-07-2004, 11:12 PM | #9 |
Rock Crawler Join Date: May 2004 Location: DFW, Texas
Looking good Kid! I like those cut and shuts! I can't believe how much axle clearance you have now with it! Awesome! Have you figured out the shock problem yet? I remember they weren't getting full compression or something.... |
10-08-2004, 06:30 AM | #10 |
Quarry Creeper Join Date: Sep 2004 Location: Michigan
How well does the winch work using a 3003? Will it pick the whole truck up off the ground?
10-08-2004, 03:23 PM | #11 |
For some reason I can't get the winch to work. It was just a test servo anyways. I think I will get a good servo, and make a better mount and stuff. I havn't changed the shocks yet, so I don't know the shock problem. I will work on my car this week. |
12-07-2004, 06:50 AM | #12 |
Newbie Join Date: Dec 2004 Location: lemont
can you post how you made the rims and tires and what you used thanks |
12-07-2004, 05:33 PM | #13 |
Hey, PM or email Texrok. He was the one I got them from.
