10-10-2004, 06:04 PM | #1 |
Newbie Join Date: Oct 2004
| wider tlt
whats the cheapest way to widen my tlt,,inetrc has widners but there 40 beans,,,thats expensive
10-10-2004, 07:05 PM | #2 |
Quarry Creeper Join Date: May 2004
| Re: wider tlt
thats probably the cheapest your gonna get. Unless you make something custom which is usually cheaper but may not work as well and will require mechanical skills. There maybe someting cheaper but inet rc parts are always top quality and look wonderful. I cannot recommend a better part.
10-10-2004, 10:56 PM | #3 |
| Re: wider tlt
hey, I can get you 12mm hexes 20mm wide for 20$ PM me if you are intrested
10-11-2004, 12:55 PM | #4 |
I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
| Re: wider tlt
Cheapest way? If you are not using your cantilevers anymore, take the long bronze piece and stick it through the bearings down in the steering arms. Then buy some RS4 MT axles and stick them through. I believe there is a little bit of shaving that has to happen to get them to fit 100% correctly though. I am not sure how wide this makes the truck, and I can't remember if I found the writeup here or at one18th.
