Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: Finished my Tuber!!! 56K Maybe...
Old 01-05-2006, 11:23 PM   #1
Default Finished my Tuber!!! 56K Maybe...
Well I put the final mounts on my tuber last night, now all I have to do is get it Powercoated and tweak the suspension...
Specs:
- Locked TLT-1 Axles
- Moabs and RPM Front pede wheels
- Pede Tranny
- Custom Tube Chassis
- Maxx Shocks
- Lathe Motor (on order, along with wideners)
- Dynamite Powerpluse ESC (for now)
- Hobbico CS-70 front servo and CS-60 rear servo
- HPI 3ch Radio modded for rear steer
Here are the pics:
Side View...
Front View... Alittle on the narrow side but wideners are ordered.
Artic Shot... stock springs alittle on the stiff side.
Artic Shot 2...
Top View:
Bottom View:
Hopfully I can get the Powercoating done next week and get some action shots!
Let me know what you think!
Later,
Jake
JakeDaSnake is offline   Reply With Quote
Old 01-05-2006, 11:27 PM   #2
Haters gonna Hate
1BadJeepBruiser's Avatar
Nice job jake, looks clean. Order up some losi whites or yellow springs and add some 20 wt oil and youll be good to go
Mike
Old 01-06-2006, 12:10 AM   #3
slugzracing's Avatar
Could you put it on a scale quickly? I am curious how much it weighs like that.
slugzracing is offline   Reply With Quote
Old 01-06-2006, 11:24 AM   #4
1BadJeepBruiser: Thanks, White Losi springs 2.5"? do you happen to have a part number?
SlugzRacing: I dont have a good scale here at the house, but I'll run by the post office on my way to work!
Im not even really sure how much it wieghts, I wanted to keep the tubing minimal cause its solid carbon steel, lol
I'll let you know...
Jake
Old 01-06-2006, 12:13 PM   #5
Sulgzracing: Its 4.6lbs without any electronics...
Old 01-06-2006, 12:25 PM   #6
Dirt Addict
roktoy's Avatar
Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Nice job......clean little chassis.
Jay
roktoy is offline   Reply With Quote
Old 01-06-2006, 12:59 PM   #7
nice work and what color are get podwder coated
rocpede is offline   Reply With Quote
Old 01-06-2006, 01:57 PM   #8
Thanks guys, Im planning on either black or silver... prob. silver if my friend has any left!
Later,
Jake
Old 01-06-2006, 02:15 PM   #9
Hey Jake, part numbers are; white springs LOSA5147 yellow springs LOSA5148 those are horizon hobbies part no's and they are $2.50 ea.
hpiguy is offline   Reply With Quote
Old 01-06-2006, 02:27 PM   #10
Loks really good, nice job!
xtman is offline   Reply With Quote
Old 01-06-2006, 08:36 PM   #11
Hpiguy: Thanks Im goin with the yellow one for now, and some 20 wt. oil!
Well I think Im gonna do the same color my XXX-T MF2 is... a black chassis with neon yellow (same as losi springs) panel made out of Lexan!
Thanks alot guys...
Later,
Jake
Old 01-07-2006, 07:10 AM   #12
Tubers are so cool. that is a nice chassis. simple but effective. whats the wb on that? and where is your battery going to fit?
lofty975 is offline   Reply With Quote
Old 01-07-2006, 08:37 AM   #13
burrlytlt's Avatar
Sweet ride, i like the front shock mounts. are you going to make body panels for it too...
burrlytlt is offline   Reply With Quote
Old 01-07-2006, 09:14 AM   #14
Lofty975: Thank man, wb is 13 inches as of now, Im gonna see how it works and may go down to 12.5... the battery location hasn't been decided yet. Im thinkin about using a 1100mah 1/18 scale pack to keep the wieght down.
Burrlytlt: Thanks, yea Im gonna add some lexan body panel on the side front and maybe back!
Later,
Jake
Old 01-09-2006, 07:34 AM   #15
Default Update:
Well I got the chassis sand blasted to go to powercoating sometime this week. I also converted my HPI 3ch radio for rear steer (radio shack 3 position switch), Biult my 1050mah 2/3A cell battery pack, and re-wired an old Dynamite "powerpulse" ESC (I think the case is trashed so it might get some heat shrink, lol)...
I'll have pics tonight!
Later,
Jake
Old 01-12-2006, 09:44 PM   #16
Default Small Update:
I got the steering converted over while the chassis is being powdercoated...
Im using a Revo pushrod (tra3919) for the lower steering link and the stock TLT as a servo link, steering the front is a CS-70MG (a 645mg basically) and the CS-60 is steering the rear (525).
I also got my shock mounts finished... I used a Dubro 3/16" duracollar and drilled it to 5mm and used a 6-32x1/2 screw in place of the setscrew. Then I cut the head off the bolt and will use 6-32 locknuts to hold the shocks on... (I had to drilled the traxxas ballends out alittle)
Sorry for the poor image quality the camera does it inside :?
Im waiting on a Lathe motor to get instock at Towerhobbies, does anyone have one they need to get rid of? If not it looks like the Tuber may take its maden crawl with a P-94 13dbl, lol
Later,
Jake
Old 01-12-2006, 10:39 PM   #17
cool idea for the shosck mounts and what is the overall lenght eye to eye for your upper and lower links please and thank u.
rich
Old 01-12-2006, 10:57 PM   #18
Very simple and clean. I don't like the tubers that look like a 20 pound jail cell. I like the way you used the collars for shock mounts. I might just have to "borrow" that idea :smile:
utbeamer is offline   Reply With Quote
Old 01-12-2006, 10:57 PM   #19
Location: a place of settlement, activity, or residence.
Nice build. Not to heavy considering it's made from solid rod. What color are you going to do the panels in?
thaclodking is offline   Reply With Quote
Old 01-12-2006, 11:28 PM   #20
Damn Jake, that thing turned out nice! I may have to give tube bending a try after seeing all these awesome tubers here.
