02-18-2010, 09:38 AM | #1 |
Quarry Creeper Join Date: Jan 2009 Location: longwood, fl
| tlt pinion gear, where to find?
I am the second owner of a set of tlt axles, the first person drilled holes in the axle pinion gears, were can i find some replacements?
02-18-2010, 10:34 AM | #2 |
Rock Stacker Join Date: Oct 2005 Location: Puget Sound
Likely the one-stop shop for all things TLT axles is gonna be www.rcpcrawlers.com In particular, you can get any of the axle parts separately! To make it easier, here is the link for the pinions themselves: TLT Pinions And if you are looking for an excuse to upgrade, you can get the solid spool and pinion from the same guys: TLT spool/ pinion (beware, this looks as though it's been drilled already) Hope this helped! |
02-18-2010, 11:17 AM | #3 |
Rock Crawler Join Date: Oct 2006 Location: Fernley
Nothing wrong with putting holes in the pinions. I've been runnin mine like that for 4 years and never had one break on me, even in my comp rig. I always had the gears break or just wear out. I just trust the pin going through more than I trust some grub screws to hole the driveshaft on.
02-18-2010, 12:25 PM | #4 |
thanks just ordered some
03-02-2010, 08:42 AM | #5 | |
Newbie Join Date: Mar 2010 Location: Downingtown
Thanks!! Andy | |
03-02-2010, 09:26 AM | #6 |
03-02-2010, 09:32 AM | #7 | |
| Quote: Thanks! A. | |
03-02-2010, 10:18 AM | #8 |
I just use the pins. I also use the metal yolks, and the pins fit just fine. Haven't been able to find just the pins to purchase separately.
03-02-2010, 12:14 PM | #9 | |
Thanks for your help! A. | |
