| | #1 |
| Newbie Join Date: Nov 2005 Location: stillwater
| i have a solution to the tlt 1 ring and pinion stripping problem. Just put a thin wahser on the axle shaft to push the diff closer to the pinion. After going through around 6 sets of gears i realized what the cause of the problem was and this is the fix that i came up with. Just an idea that some of you might want to try if you have the same problem. |
| Sponsored Links | |
| | #2 |
| Rock Stacker Join Date: Dec 2005 Location: Albuquerque
| I've gone thru 3 ring and pinions. Could you post pics. Thanks |
| | #3 | |
| 2006 2.2 National Champ ![]() Join Date: Dec 2004 Location: Driving my R/C rototiller
| | #4 |
| Pebble Pounder Join Date: Oct 2005 Location: The arm pit of the universe
| Can you shim the pinion towards the ring gear? Just like a real r&p set up? |
| | #5 |
| Bender, I have bearings. I noticed that there is some play in the pinion. I tried to shim it so that it was closer to the ring gear but it was too tight. I may need to find a thinner shim. |
| | #6 |
| Rock Stacker Join Date: May 2005 Location: castlerock
| I have broken many drive shafts and stripped several hexxes but have had no trouble with my gears. I shimmed the pinion into the ring during assembly and haven't had a problem yet. |
| | #7 |
| Quarry Creeper Join Date: Jan 2006 Location: Winston-Salem
| I hanen't stripped any gears yet but noticed that when you turn the axle on one end, it rolls smooth. When you turn it the other way, it's not as smooth. I shimmed one axle and when I did the other, it was a little stiff. I used a piece of the thin washer that comes with the spare r & p parts. |
| Thread Tools | |
| Display Modes | |
