11-04-2004, 02:33 PM | #1 |
Rock Stacker Join Date: Apr 2004 Location: St. Louis, MO
| VMG with 99.96:1 Gearing!
I successfully installed a 6.6:1 gear reduction unit! http://www2.towerhobbies.com/cgi-bin...LXHHK1&P=0 I had to do Lots of custom work! But it is mounted solid. The unit it's self is 6.6:1 Reduction. Then on the output I mounted an 8 Tooth Pinion. So I am not sure just what the final gear ratio is. However, it is very slow, ton's of torque, and Fanomal throtle control now! I can truly crawl!!! The unit is nice. I was suprised to see Ball Bearings where the shafts ride in the unit. This unit was only $16 at my LHS. I was going to get the Great Planes unit but this was a higher reduction and was in my hand at the LHS. So I bought it! The Stock Motor & Fireball will fit right in to this gear reduction unit. I ended up using the motor that came with the gear reduction unit, it was new and my stock motor isn't. I will get a fireball soon. Below you can see the two Machine screws that I drilled through the frame into a pocket on the unit and bolted it down with nuts. No Movement! Spare frame parts are glued and screwed to the top plate then screwed to the unit for a solid mount. This thing does not move. I am waiting on my Swami Mounts for the steering. I have a rigged up plate that I made that works but I want the clean and solid Swami Mounts. I will complete assembly in a day or two when they come in. For now I hooked up the complete rearend and it was awesome slow controled power! Right now my gearing is 6.6:1<>15.1:1= 99.96:1 Final Ratio |
11-04-2004, 02:37 PM | #2 |
Pebble Pounder Join Date: May 2004 Location: east coast
| Re: VMG with 99.96:1 Gearing!
thats cool matt |
11-21-2004, 11:30 PM | #3 |
RCC Addict Join Date: Nov 2004 Location: Redding, CA
ive got the same reduction for mine but i rotated it down so it was centered in the chasis more with a lower cg |
11-22-2004, 09:15 AM | #4 |
I mocked up several different mounts but this way is rock solid. No flex in the mounting. If I do an AL frame I will be able to make cross bars to keep it solid in a horizontal position. Please, post some pics of it so I can see how you monted your. Thanks! Now on to the 4ws! |
11-29-2004, 05:38 PM | #5 |
tried to post the pics but digital camera pooped out
