Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: unloading center diff
Old 02-24-2006, 06:33 PM   #1
Default unloading center diff
I was just thinking inside of a pede tranny is you had a spring loaded diff so if its under pressure it releases a jerk of power when the spring is unloaded, i wonder if anyone could make something like that or if you guys think its a good idea, im sure this has been passed around before
savageracer312 is offline   Reply With Quote
Old 02-24-2006, 09:07 PM   #2
You know what an impact wrench can do to a seized bolt?
Think about what that would do to a axleshaft when the tire is stuck under a rock.
Tacoma747 is offline   Reply With Quote
Old 02-24-2006, 09:14 PM   #3
Unhappy
Why would you waste the time let alone money on that tranny? Would the spring be worth the trouble?
ColquittCustom405 is offline   Reply With Quote
Old 02-24-2006, 09:32 PM   #4
I don't understand how this would help you. Do you not have enough power to get your tires out of a bind? If not, then your not geared properly. You need a GD600. With my MM and GD600, my motor will not stall if the wheels get in a bind, they will snap axles or any other weak link in the drive line.
AdamF is offline   Reply With Quote
Old 02-24-2006, 10:25 PM   #5
its like an impact screwdriver , you twist and twist then pop spung unloads and bolt is loose, in this situation your back tire is stuck under a rockand it loads up and releasesand the front axles jerks it out of the position
Old 02-25-2006, 08:34 AM   #6
that pop you talk about would be driveline breaking.
if your tire gets bound up take the point , backup, pick another line.
flatfender is offline   Reply With Quote
