Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: Spur and pinion gears
Old 04-09-2006, 12:07 PM   #1
Default Spur and pinion gears
I tried searching but couldn't find my answer. What is the best pinion and spur set up for a TLT crawler with 2.2s and a 45t motor?
BigD74 is offline   Reply With Quote
Old 04-09-2006, 12:25 PM   #2
it really depends on what you want... torque or speed.... with my 55t lathe motor i run a 16/87 and it seems to be the best combo of both worlds...
nd4spdbh is offline   Reply With Quote
Old 04-09-2006, 12:28 PM   #3
I don't need speed just the ability to crawl and have enough wheel speed if I need to bump up and over something.
Old 04-09-2006, 01:09 PM   #4
I run 12/87 with a 55 turn lathe and it works great.
redneckracer1979 is offline   Reply With Quote
Old 04-09-2006, 01:44 PM   #5
well then go to your LHS or whatever and ask for the biggest spur gear avalible for a stampede and then yep you guessed it, ask for the smallest pinion to go with it.
Crawlsalot is offline   Reply With Quote
Old 04-09-2006, 03:54 PM   #6
87/12 here and I love it.
customxprone1 is offline   Reply With Quote
Old 04-09-2006, 11:43 PM   #7
87/13, 55 turn. Lots o torque, fair amount of wheel speed. You'll just have to play around with pinions till you find a setup that suits your driving style....But like mentioned before buy the biggest spur you can find.
FlexinTLT is offline   Reply With Quote
Old 04-10-2006, 12:09 AM   #8
55t 14/90 good torque and speeds ok
brendan h is offline   Reply With Quote
