05-05-2006, 02:55 PM | #1 |
Rock Stacker Join Date: Nov 2005 Location: School and work
| RC4WD Wheels Narrow Beadlocks
Has anyone used these wheels, I just received mine and when I try and use the washers they provide the outer shaft doesn't even come close to hitting the first thread. I noticed there is two lips inside the hub area my washers sit on the outer one, should I have received smaller washers or am I totally retarded and doing something wrong?
05-05-2006, 03:06 PM | #2 |
Quarry Creeper Join Date: Jan 2005 Location: UK
do you have any pics to help explain?
05-05-2006, 03:12 PM | #3 |
Rock Crawler Join Date: Jul 2004 Location: OC, Oregon
Im not using the washers. Mine didnt fit either. If i recall theres a thread in the vendor section about this problem. Edit: Did some looking around, heres the post i was thinking of http://www.rccrawler.com/forum/showp...4&postcount=28 But says if you need a bigger washer? maybe he was just mixed up or something. Give them an email and they should be able to help you out. Or like i said i dont run a washer, just a normal flanged nut and i have yet to have a problem. Last edited by TerribleOne; 05-05-2006 at 03:23 PM. |
05-05-2006, 08:42 PM | #4 |
Newbie Join Date: Feb 2006 Location: Duvall
I also don't use the washers... I bought GMade Axle extenders from the Crawler Store, they come with Washers that fit and the Extenders help with clearence issues. |
