05-05-2006, 11:02 PM | #1 |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
| Rockwerks TLT build...UPDATED
Ive built a bunch or other RC stuff over the years but never a crawler, Parts axles TLT trans Losi JRT motor lathe 55t custom chassis custom links 2.2 rims proline masher 2000's body 13 year old McCalister truck 4 Losi 3.5" shocks lots of old RC hardware I decided to build my own laydown chassis.......about 2.5" wide and taperd to 3.5" at the top. and a total of arond 2.25" tall I will be running 116mm links on both the front and rear lowers and with ride height at 2.75" it lays out to 12.25" wheel base. I will post more tomorrow as I progress with the build Last edited by rockwerks; 05-07-2006 at 09:04 PM. |
05-05-2006, 11:05 PM | #2 |
Interesting. Good luck! And BTW, I used to run that body on my RC10T in the early 90's! |
05-05-2006, 11:08 PM | #3 | |
05-06-2006, 08:27 PM | #4 |
well made some progress today got a ocuple of hours of time on it........still need to adjust the upper links at the axle up about 3/8", flexes without shocks to about 80* total.....at full flex the Drive shafts just scrape the upper arm.....if I get time tomorrow shock towers Ground clearance is right at 2 3/4" @ 12 3/8" wheelbase front flex side flex......... |
05-07-2006, 06:20 AM | #5 |
Nice truck! Those pics made me thirsty for a fresca... |
05-07-2006, 09:03 PM | #6 |
| Well worked on my sons real crawler most of today but did get time to fit the body, make the shock brackets and mount the shocks, Im gonna make the front brackets same as the rear. an alum hoop......nice for roll protection I need to make taller upper arm axle brackets about 1/2' taller to help with axle twist. I will make those tomorrow I am going to mount the motor and tranny on a little less of an angle that I have it sitting in the picture to equal out the drive line angles |
05-09-2006, 04:26 PM | #7 |
Pebble Pounder Join Date: Feb 2005 Location: Flagstaff
| tlt
Mmmmmmm......fresca!!!!!!!!!!!
05-09-2006, 04:53 PM | #8 | |
