05-15-2006, 08:38 PM | #1 |
I wanna be Dave Join Date: Mar 2005 Location: Hiding from Goodall
| Re-thinking the RBX
I have been screwing around with this for a while and I wanted to post up a couple pics before I tear it down and try something new. I ran the RBX with virtually no changes this last season and there were several things I did not like. Obviously the center of gravity was not low enough (it never is) and the chassy was just to wide. The skid surface is massive esp once you bring the ride height down. This is the first idea I had to try and eliminate some of the issues and overall it works quite well. I ditched the skid and mounted the tranny with the motor serving as the new smaller skid surface as well as moving the center of gravity way down. This also allowed me to narrow the chassy to a point I was happy with. The only downside is that the break over angle sucks and can bite in really rough technical areas. For steep slickrock it is a dream come true with very stable side hilling and what seems like an improved climbing ability. If I could get the tranny up a little higher I would run this setup for the next comp but that is as high as I can get it and not bind the front drive shaft :? |
05-15-2006, 10:28 PM | #2 |
I wanna be Dave Join Date: Nov 2005 Location: Crawler practice!
why dont u make youw own chassie with that desighn but no hole so you can drop the tranny out the bottom nnot the motor
