Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: how slow???
Old 12-09-2004, 06:37 AM   #1
Default how slow???
I am wondering if I should buy the GD600 with a bunch of other things from Towerhobbies. I have a 9 tooth pinion and lathe motor, going to be running it through a stock TXT tranny with stock TLT axles/gears, with 2.2 Imex Swamp Dawgs. I plan on doing mostly crawling but also some general wheeling with it. Is the GD600 going to make it creep too slow to use for anything besides crawling?
rockhound is offline   Reply With Quote
Old 12-09-2004, 08:28 AM   #2
Default Re: how slow???
Yes, with a lathe motor, the GD600 will make the thing slow as molasses in the winter. Lathe motors don't need gear reductions.
Plays_with_Toys is offline   Reply With Quote
Old 12-09-2004, 09:22 AM   #3
I was sorta figuring that - thank you.
Old 12-09-2004, 09:28 AM   #4
Diggin' the new SCX10 II!
badger's Avatar
I disagree, I run a lathe motor with a Mammoth gear reduction and a 15T pinion. It has great crawl ability and a little wheel spin.
Now if I put a 9T pinion I would have no wheel speed.
badger is offline   Reply With Quote
Old 12-09-2004, 10:00 AM   #5
Badger, is this on a TLT with 2.2's or a something with larger tires, because the larger tires will create a higher over all gear ratio than smaller ones.
I say, leave the GD600, get everything else, and see if you need to go lower. If you do, then pony up for a GD.
Old 12-09-2004, 10:29 AM   #6
Powered by Awesome
TwistedXT's Avatar
the size of the tires will only affect how far the trucks travels per every one wheel rotation. the gear ratio is how many times that the motor spins to how many times the outer axle shafts spin... so for example:
40 motor turns = 1 wheel turn = 40:1 ratio smaller tires will effect the overall crawl speed... sorry, dont meab to sound like a ... well... you know. its the pain meds talkin 8O , stupid bumb shoulder
TwistedXT is offline   Reply With Quote
