06-04-2006, 01:37 AM | #1 |
Quarry Creeper Join Date: Jan 2006 Location: Winston-Salem
| Finally got started on my rebuild.
Finally got started on the rebuild of my rig tonight. Been putting it off for a few days now. Got the pede mocked up in the chassis and still have some trimming to do around the spur gear and motor area. Chassis looks like poop right now but it will be painted when it's finished. Got a few parts on order from tower too. I have to replace a stripped diff. and pinion gear so figured I'd start the rebuild. Also got spare axle shafts, gears, cases ans a Super Brain 959 coming. Here's the original and the first rebuild pics. More to come. Comments welcome. Last edited by scruff007; 06-10-2006 at 06:28 AM. |
06-04-2006, 08:09 AM | #2 |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
You are going to want to countersink those screws on the bottom. You would have been better off only screwing them in from the side. They will get hung up on stuff.
06-04-2006, 09:25 PM | #3 |
Got a bit more done tonight. Need to shorten the upper links and get the elecs. mounted. Waiting for my traxxis rod ends and axle parts. WB is now 12". Was 11.5". |
06-09-2006, 03:29 PM | #4 |
Finally got my rig done today. I can't beleive the difference with the pede tranny and better COG. Thanks for all the info. from the site you guys! It is seriously impressive. Here it is. Last edited by scruff007; 06-10-2006 at 11:33 PM. |
06-11-2006, 09:56 AM | #5 |
Rock Crawler Join Date: Aug 2005 Location: Concord, NC
Looks good Brian. It has more of a scale look now. You may need to stand the rear shocks up a bit. I did on my TLT and it helped the torque twist a bunch. You will figure it out once you run it a little. I put a Courier body on my TLT for more of a scale look. Can't wait to see your new setup in action. |
06-11-2006, 03:08 PM | #6 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
looks pretty good scruff. trying to get started on my nylint tuber now and almost done with my clod tuber for now didnt break last time we went to bullhole cant believe it.. |
06-11-2006, 03:20 PM | #7 |
Quarry Creeper Join Date: May 2006 Location: Georgetown, Texas
Nice rig, i like it!!!
06-11-2006, 03:37 PM | #8 |
Thanks guys. There isn't really much torque twist to it Brando. At full throttle from sitting still the front tire barely comes off the ground. The chassis have very little weight on it. The good thing is the shocks have those collars on the so you can slide them down to stiffen up the shock. See you guys at the next G.T. Hope it's going to be soon. I'm getting bored just running it around the house.
06-11-2006, 05:12 PM | #9 |
Rock Crawler Join Date: Mar 2006 Location: Benson,NC
Man i bet that made a world of difference.Looks good,would have looked better with a chevy body though! |
06-12-2006, 02:55 AM | #10 |
I chose the early bronco because I like the look. And It had large wheel wells. I didn't want to trim the wells unless I had to but it's fine. If I had wideners I would have to trim alot. I like the Jeep Rubicon body too but it had to many small parts on it to be painted different colors. Like the winch and stuff. That's to much detail for me. It probably wouldn't have turned out like the bronco did. Thanks
06-15-2006, 11:19 PM | #11 |
Newbie Join Date: May 2006 Location: in a house
coool rig
