Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Teaserof my comp TLT
Old 06-04-2006, 08:20 PM   #1
Web Wheeling
Etype R's Avatar
Default Teaserof my comp TLT
Height of beverage bottle in the picture is 7 inches. This is maxxing out the suspension. I have a behind the axle steering setup that I did several months ago, seems to work pretty good.
List of things to finish before I can test run it.
Rear drive shaft, need to buy some tomarrow
Relock the diffs, had the open for awhile.
Solder connections to the ESC, brand new Tekin Rebel 2.
Then after I test it out, if it handles well I need to finish it. I'll have to replace a few of the brackets. Add body posts, glue the tires after I decide how I want to run the foam. And a few other minor details.
Here is the teaser shot.
Etype R is offline   Reply With Quote
Old 06-04-2006, 08:26 PM   #2
Looks like too much flex to me.
Cole82 is offline   Reply With Quote
Old 06-04-2006, 08:41 PM   #3
X2 , too much, ease it back man
Unimoger is offline   Reply With Quote
Old 06-04-2006, 08:47 PM   #4
Web Wheeling
Etype R's Avatar
I am thinking it is to much as well. I will probably put some spacers in the shocks. But before I limit anything, I want to do some testing. I just slapped most of it together last night, and finished a little more earlier today.
Need to have it finished this weekend for a comp.
Old 06-04-2006, 09:28 PM   #5
The more flex you have the more chit breaks.You'll be surprised what 60 degrees of felx can do for ya'.Looks good man.
ColquittCustom405 is offline   Reply With Quote
Old 06-04-2006, 10:03 PM   #6
X20.............limit if it does not work well for you.....and flex dont break chit.....poor driving does
Im very happy with the way my truck works...I need to make some small adjustments bu the truck at this point is much more cpable than my driving skils..and if I listened to these guys nothing I did would work, too much travel.......paralell links dont work, yada yada yada..........build it the way you think is right, then tweek it for YOUR driving style..not someone elses
rockwerks is offline   Reply With Quote
Old 06-05-2006, 12:32 AM   #7
really good quality picture, I like it, looks like it will be an awesome crawler
CrawlAZ is offline   Reply With Quote
