Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: My new TLT chassis
Old 06-11-2006, 03:56 PM   #1
Default My new TLT chassis
Well since Alice took ownership of my the lil truck I did last month. I needed to build a new one. I based this chassis of my other one, with shock and arm locations in the same place....it is jsut as compact but much lighter about 4.5 oz. total weight including screws and upper arm mount hardware.
cut out with my plasma cutter and hand finished. I thought the black screws look pretty good with the black fibered ABS and alum sides. NOw to build the upper arm axle standoffs and 1/4" alum solid arms.......anyone got a set of juggy or TXT or TLT axles the might one to part with
I designed it low only and as narrow as I could, its very ridgid and can be used with any of the trannies Ive got laying here, stealth with is in the pics, kyosho ST, Losi X's or pede......the chassis is offset to the front for a 60/40 weight bias.....whatcha think?
rockwerks is offline   Reply With Quote
Old 06-11-2006, 03:58 PM   #2
That looks sweet. I really like the lines. Makes it interesting instead of just flat al.
Cole82 is offline   Reply With Quote
Old 06-11-2006, 04:02 PM   #3
I have diamond plate to....a 48" x 96" piece........but I thought this was kinda cool and the lines make it easy to drill holes by hand..
Old 06-11-2006, 04:02 PM   #4
dezfan's Avatar
Like it much more than the first one.
dezfan is offline   Reply With Quote
Old 06-11-2006, 04:03 PM   #5
that one was kinda a working though the design in my head.........looked like a row boat huh LOL
Old 06-11-2006, 04:27 PM   #6
I really like the lines as well, diamond plate would be sick too, not sure which one I would like more, but fabulous job!
CrawlAZ is offline   Reply With Quote
Old 06-11-2006, 04:37 PM   #7
This is easy to drill the diamond plate would look sick but be a pain to drill, you would have to drill to all from the back side, then clean up the drill holes from the front.
Old 06-12-2006, 07:40 PM   #8
J_Bone's Avatar
Sick, can't wait....
J_Bone is offline   Reply With Quote
Old 06-12-2006, 09:24 PM   #9
Oppan Gangnam Style
chino63's Avatar
was it once a door sill plate? looking good no matter what it used to be!
chino63 is offline   Reply With Quote
Old 06-12-2006, 11:26 PM   #10
nope but it does look like it dont it........
Old 06-13-2006, 03:38 PM   #11
My guess would have been extruded running board
Bobtail74 is offline   Reply With Quote
Old 06-13-2006, 03:39 PM   #12
its jsut milled alum I buy from my supplier for the 1:1 business.........thought it looked cool and with the horizontal lines its very easy to line up positions for new holes for modding things.
Old 06-13-2006, 06:16 PM   #13
HMMMMMMM!
doubledub is offline   Reply With Quote
Old 06-13-2006, 06:28 PM   #14
Originally Posted by doubledub
HMMMMMMM!
all right its 8' lengths of 6" wide sill plate. I have found several other patterns for my supplier also. might try a small tripple chevron diamond plate...
Old 06-14-2006, 11:52 AM   #15
ahhhhhhh!
Old 06-15-2006, 08:40 PM   #16
chassis with arms and axle stand offs, looks like 116mm lower arms and 112mm uppers.......now all I need is some axles............anyone?
Old 06-15-2006, 08:48 PM   #17
dezfan's Avatar
Is it just the picture, or are the upper links longer than the lower links?
Unique upper link mounts for the axle.
Old 06-15-2006, 08:53 PM   #18
the upper links are 4mm shorter than the lowers. The axle upper link mounts use the stock axle holes and the spread allows me to place the battery packs modified flat and around the servos........lowers the CG by a ton...I have the same mounts on my other truck. they also make it 100% stable side to side and zero bind, very smooth action
see the standoffs on the rear axle and the 2/3a battery packs 7 cell wrapped around the servo?
Old 06-15-2006, 08:58 PM   #19
dezfan's Avatar
Must be an optical illusion. Do you mount the battery on top of your servo? Or break the pack into smaller sections?
Old 06-15-2006, 08:59 PM   #20
LOL see edited above
front pic.......the 7 cell wraps around the servo.
