06-11-2006, 04:23 PM | #1 |
Pebble Pounder Join Date: May 2006 Location: Scottsdale
| New and improved SW2...
Well I decided after getting my TLT SW2 mocked up and running it a little, it was time to change battery location and make things a little cleaner. The battery used to sit towards the back leaning on the tranny. I knew I wanted the weight forward, but I also wanted to drive the friggin thing! But let me tell you after putting the battery up front it has made a world of difference! Completely different crawler. Also I cut about 6 inches off the wire to the motor and now it is like 2, I think it gave it a little more umpfh. Maybe it's just in my head. Anyways tell me what you think and things I can improve on (besides swapping the axles front and rear I made that mistake and I think it will stay that way for a while). P.S. check out the fog lights on the battery |
06-11-2006, 04:26 PM | #2 |
I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
Get real tires on that bad boy. Masher 2000 work really well. Allso remove the servo saver. Use a standard horn. |
06-11-2006, 04:29 PM | #3 |
What's a standard horn? Yeah I need real tires REAL bad, im gettin moab's though. Here is a before pic. |
06-11-2006, 04:46 PM | #4 |
When you get the bigger tires with more traction. The servo will turn but the tires won't. If you have a servo horn ti will turn the tires, not the servo saver. Nice lights by the way. |
06-11-2006, 05:13 PM | #5 |
sounds like a necesity, but (excuse me here im a newbie to crawling) what IS a servo horn? haha
06-11-2006, 05:22 PM | #6 |
06-12-2006, 02:15 AM | #7 |
Quarry Creeper Join Date: Jan 2006 Location: Winston-Salem
Most servos come with multiple horn with them. I used the one that's just a big round horn and you can drill holes accordingly. It resembles a diff. brake on a Rockwell 2 1/2 ton axle. You may want to shorten the upper or lenghthen the lower links to level out your front axle. It may put a little more stress on the axle with it kind of steering towards the ground.
06-12-2006, 06:35 AM | #8 |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
also, when you put 2.2 wheels and tires on it, you'll probabally want to lower it altogether, it already looks like you are getting about 3 inches of under belly clearance already, but when you put the bigger wheels and tires on, it will raise it between 1 and 1.5 inches, which will put your center of gravity WAAAAY too high.
06-12-2006, 07:26 AM | #9 |
Doesn't Bender build them with the intent of having the motor on the driver's side?
