06-18-2006, 09:09 PM | #1 |
RCC Addict Join Date: Jul 2004 Location: The other Crawler State
| The "Punisher" with 2.2 RR's |
06-18-2006, 09:10 PM | #2 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
Same as K rocks but for 2.2?
06-18-2006, 09:15 PM | #3 |
Rock Crawler Join Date: Dec 2005 Location: houston
Red rocks with extra lugs glued on!!? looks sick!!! Rig looks great too.
06-18-2006, 09:18 PM | #4 |
And you just used CA glue to do that right?
06-18-2006, 09:23 PM | #5 |
read the 2.2 tire thread on these tires, last page. |
06-18-2006, 09:25 PM | #6 | |
The SW2 chassis can't be beat, and a good set up should take ya to the top with good driving. This is not a "cheap" TLT. the servo alone is $140. | |
06-18-2006, 09:53 PM | #7 | |
There is nothing wrong with a Pede trans set up, it is tuff as hell and if set up right will crawl with the best of them. Besides, you can build whatever, but a really good driver will run circles around whoever. | |
06-18-2006, 10:01 PM | #8 |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
that looks sweet, looks like a lot of time put into those tires
06-18-2006, 11:10 PM | #9 | |
but well worth it. | |
06-18-2006, 11:13 PM | #10 |
Pebble Pounder Join Date: Sep 2005 Location: Bellevue
lets get a video comparison...i want to see em work |
06-18-2006, 11:24 PM | #11 | |
I have always run a slipper on a Pede tranny ( 2 years now) cranked down and it has always worked and hardly ever slipped. When it does it slip, it is about 1 second in a hard bind and the motor will stall or an axle will break. With a stock slipper on a pede, and not the worthless adapter, you can run a 12/96 gearing with a steel yoke on the trans. That gives ya 8:1, with a change to a 13t pinion (13/96) you are at 7.38 which is good for smaller tires and not bad at all with a 8.4 volt set up with any tire size. I never seen the need for 64p gearing, but you do have a little better range to work with. As far as braking I just adjust the trim on the throttle and the rig holds true and just use the brake on the esc for going down hill if needed. I have seen a lot of stuff not needed on the TLT for years and I am just now speaking out about what I have been running because of 2 years worth of proven ways. To each his own, but I know what works for me, and can work for anybody. | |
06-18-2006, 11:33 PM | #12 | |
Rock Crawler Join Date: Jan 2005 Location: Tumwater
Tires look interesting Doug! Chad- | |
06-18-2006, 11:35 PM | #13 | |
They are doing way better in my test area than any 2.2 Moab I have tried. I also have a new set of M2ks I have bought for a comparison and they do better than those do because of size and now have more grip than a Masher when you hang on to the rig and do a burn on the pavement. The 2.2 RR's I made up pull a lot harder than the Mashers on that test for sure. I tried the M2k's with and with out foams and the same weight on the "burn" test. With out foams the Mashers had more pull than with foams but still didn't have the pull the 2.2 RR's I made up. The one thing this large tire will do is beat up the little TLT quicker but I don't care, that would be a maintenance thing and expected. | |
06-18-2006, 11:39 PM | #14 | |
I myself would think a change over to CF and derlin links would yield about the same. I am just guessing at that in theory. Also the mounting plate for the uppers could be drilled out a bunch and you wouldn't hurt a thing. Hey Bender! How about a CF SW2. I have never mess with a brushless system yet. | |
06-18-2006, 11:48 PM | #15 | |
grams are for drugs aren't they?? another thing, batteries weigh way different from one another. The old school 1500 NiCads are the lightness and have more than enough run time for comps. I now about the lipos, but I don't think I am ready for a picky batt like that just yet. I have 2 nice Tekin chargers I am not ready to give up yet also, so Ni Cads or NiMH will have to do for awhile yet. | |
06-18-2006, 11:53 PM | #16 | |
Wow!! the cost has dropped big time I guess, I might have to try out a brushless system. How is the reliability? and how long is the maintenance duration on these if any?? I have seen what the brushless system can do on the go fast RC's and I was impressed with the power. as far as tires?? Tires are everything in motor sport what ever the size is, and I spare no expense when it comes to tires. | |
06-18-2006, 11:55 PM | #17 | |
My float with large bat and brushless was under 3.5lbs with weight in the front tires...I have never weighed it with the lighter lipos. Chad- | |
06-18-2006, 11:59 PM | #18 | |
Chad- | |
06-19-2006, 12:00 AM | #19 | |
Thanks for the complement! | |
06-19-2006, 09:13 AM | #20 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
The Revolver/Mamba combo is ALOT lighter, compared to my Lathe motor and Super Rooster set-up. I added a little more weight to my axles because I felt it was almost too light. I'm not sure a CF chassis would be a good thing. Skippy built a 3 3/4 lbs 2.2 rig and it couldn't get any traction on steep climbs. He also ended up adding weight to the axles. That's the same reason I like my standard 6 cell packs, I think the added weight helps my rig. That's seems to be what works here in Colorado at least. My uncut Pede tranny housing protects my Revolver motor perfectly, another reason I like that tranny. I've never had any problems with my slipper clutch either. | |
