Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: striped diff
Old 06-26-2006, 06:21 PM   #1
Default striped diff
i just striped the rear diff in my tlt. can you get spar parts. i need the crown and pinion, diff case, gears inside and maybe the drive shafts.
anyone know where i cna get them?
brendan h is offline   Reply With Quote
Old 06-26-2006, 06:34 PM   #2
Gold Star Baby Momma!
Tower Hobbies
Tuffguy is offline   Reply With Quote
Old 06-26-2006, 06:36 PM   #3
yer tower only has the crown and the cover for it. and the drive shafts
does any other tamiya car use tlt diffs?
Old 06-26-2006, 06:42 PM   #4
I think maybe the new f40 highlift might up front. It is to new to know.
revoster is offline   Reply With Quote
Old 06-26-2006, 06:44 PM   #6
never mind i think i found all ther parts. i might make a nother crawler its gana be cheap 2/.
Old 06-26-2006, 06:48 PM   #7
DUDE's Avatar
brendan h,
shim the ring gear up to the pinion really good, but spin freely, you won't do that again.
DUDE is offline   Reply With Quote
Old 06-27-2006, 08:55 PM   #8
What are you using for a shim? I shaved down a washer and it properly destroyed the ring and pinion gears in that axle.
JeremyH is offline   Reply With Quote
Old 06-27-2006, 10:36 PM   #9
DUDE's Avatar
5mm I think? the ones I have used are from a Losi XXT race truck, I think they are bearing shims?? or diff shims?? hell I can't remember for sure.
Old 06-28-2006, 04:56 AM   #10
Ahh....thanks for the tip.
Old 06-28-2006, 05:54 AM   #11
sods's Avatar
I used traxxas part# 1985 too shim mine.
sods is offline   Reply With Quote
Old 06-28-2006, 05:52 PM   #12
Awesome! Thank you.
Old 06-28-2006, 06:27 PM   #13
No way, You got a Custom striped diff for your tlt. Thats pretty cool, wanna stripe mine ? , You mean Stripped. Shim with the 1985's and youll be good.
joshm101 is offline   Reply With Quote
