07-03-2006, 05:43 PM | #1 |
RCC Addict Join Date: May 2006 Location: Roseville
| Pede axle issue
I am having a devil of a time getting the ball into the universal joint on the tranny side of things. Is there a trick to doing this? I can get the ball into the sliders just fine, but the yokes (is that the correct term?) is a no go for me. Help me RCCraler.com-Obi, your my only hope. |
07-03-2006, 06:38 PM | #2 |
Rock Stacker Join Date: Nov 2005 Location: Northfield
take a lighter and heat up the ends of the slider then take a pliers and pry them apart a little bit now stick one end of the outdrive into the slider then with a flat scredriver push the other end into place. hope this helps
07-03-2006, 06:42 PM | #3 |
Quarry Creeper Join Date: Dec 2005 Location: Albuquerque
i hated that stuff it sucked buting thos in. i used a vice to do them squeze them enouth wherer they expand and the thake the pressure off it and BAM it works.
07-03-2006, 10:28 PM | #4 |
I was able to get it with two needle nose pliers (I held both pliers) and splitting the two arms where the ball goes in and having my loving wife (she was tired of hearing me cuss at them whenever I would pinch myself or have one fly across the room) use her little fingers and get the ball in place. Then I used a pair of channel locks to pop the ball the rest of the way into place. Talk about a nightmare (at least a cuss-fest).
07-04-2006, 01:18 AM | #5 |
Rock Crawler Join Date: Sep 2004 Location: eureka
the way i do it is i take the plastic parts and I hold them under running hot water to get them more flexible. then i just use the same pair of pliers to slide in one pin of the u-joint piece into the plastic shaft. then i just use the pliers and push the other side down and it pops right in , then i put it under cold water while squeezing the plastic on both sides of the u-joint together, to help make it a tighter fit dont know if im weakning it that way , never broke a pede driveline but now im usin maxx lines just to be sure
07-04-2006, 01:33 AM | #6 | |
07-04-2006, 03:48 AM | #7 | |
Rock Stacker Join Date: Nov 2005 Location: Perth, Australia
07-04-2006, 06:50 AM | #8 |
Pebble Pounder Join Date: Sep 2005 Location: minocqua
07-04-2006, 08:27 AM | #9 |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
all you guys make it way to complicated, all ya do is start the ball in one ear then using the edge of a table (needs to be square edge) on the edge of the ball, push down and towards it at a 45* angle. no fuss no muss and takes about 5 seconds per side
07-04-2006, 10:32 PM | #10 | |
Quarry Creeper Join Date: Feb 2006 Location: Shillington
07-05-2006, 12:38 AM | #11 |
Revo Shafts and Joints are alot easier and Beefy.
07-05-2006, 12:47 AM | #12 | |
07-05-2006, 06:10 AM | #13 |
you can just slot the tip of a standard screw driver.
07-05-2006, 12:04 PM | #14 |
Rock Crawler Join Date: Feb 2006 Location: Easthampton
i use a pair of snap ring pliers to spread them open
