07-05-2006, 01:44 AM | #1 |
Newbie Join Date: Dec 2005 Location: Salem
| What to use over links?
I have a 4-link suspension and the 4-40 threaded rod I used bent really easy and I had nothing covering it. My question is what should I use to cover it? Like aluminum, graphite, brake line, steel, etc?
07-05-2006, 02:00 AM | #2 |
3/16 Brakeline is cheap. It will hold up a lot better. I know someone that can make you some C.Fiber links for a Good Price.
07-05-2006, 02:28 AM | #3 |
Is that the correct size over 4-40 rod? I don't know what size I need to fit over the 4-40.
07-05-2006, 03:00 AM | #4 |
Look over this site for more info. http://www.mcmaster.com/ |
07-05-2006, 03:05 AM | #5 | |
07-05-2006, 11:38 AM | #6 |
I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
Carbon is the way to go. Look at the last pictuire on the right. http://www.midwestproducts.com/carbonfiber.htm |
07-05-2006, 04:09 PM | #7 |
I think the carbon was cheaper than the brake line. I'll check it out. EDIT: Nope more money but not much. IT's $3.99 for three feet. Last edited by Cole82; 07-05-2006 at 06:00 PM. |
07-05-2006, 05:47 PM | #8 |
Rock Crawler Join Date: Apr 2006 Location: pasco,Wa
1/4'' delrin rod is cheap and way lighter
07-05-2006, 06:35 PM | #9 |
what is delrin rod?
07-05-2006, 06:37 PM | #10 | |
Delrin is a type of plastic that is very durable. | |
07-05-2006, 06:40 PM | #11 |
Yes very similar. It does hold threads ok. It's more flexable than cutting board though. It's like a plastic coat hanger.
07-05-2006, 09:28 PM | #12 |
Quarry Creeper Join Date: Oct 2005 Location: Bryant, AR
I wouldn't go with carbon on the lower links. I had lower carbon links and they broke on the first hard hit on the rocks. I do use carbon for the uppers tho.
07-05-2006, 09:49 PM | #13 |
I'd got to the .99 cent store and buy some coat hangers. Cut them, drill them out and tap them. Cheap and lots of pretty colors! |
07-06-2006, 01:30 PM | #14 | |
07-06-2006, 04:50 PM | #15 |
would brake line be to heavy for a tlt? But wouldn't the cg be lower since there is more weight lower (brake line on the links)
07-06-2006, 05:05 PM | #16 | |
07-07-2006, 09:58 AM | #17 |
you cant beat delrin for this i strongly believe its the best way to go. Lighter is better 1:1 buggies are getting lighter and lighter.Theres agood reason for that.
