Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: latest tuber project
Old 07-09-2006, 06:22 PM   #1
madscrambler's Avatar
Default latest tuber project
Sold the blackwidow but missed it so much built a new one and added some improvments axle mounted 4 links a 2 3/4 ground clearance 12 1/4 wheelbase stampeede shocks its still a work in progress I built a new comp rig light weight and need to do some testing to see just how much the added wieght helps or hurts so stay tuned for the results by the way I do have a extra chassy I built earlier its almost the same as the other black widow if anyones interested give me a pm.thanks
madscrambler is offline   Reply With Quote
Old 07-09-2006, 06:25 PM   #2
Default one more pic
sorry for the por quality of the pics but enjoy anyways
Old 07-09-2006, 07:31 PM   #3
looks sweet so far, I like how you mounted the upper links in the rear like a 1:1 would have
Crawlsalot is offline   Reply With Quote
Old 07-30-2006, 11:25 PM   #4
Default finished her up
Back from Alaska and finished up the black widow 2. tested her out and did some comparision between the light weight comp rig and the tuber . But thats for a later post . It has the usual pede tranny 55 turn lathe stampeed shocks 3/16 steel rod about 6 ft. lrp speed control cheap radio . this is my 3 year olds bashing rig so didnt want to put to much into it .. he can drive very well for his age just training him up right.
Old 07-30-2006, 11:28 PM   #5
is that your personal rockpile?
Got Rocks? is offline   Reply With Quote
Old 07-30-2006, 11:29 PM   #6
Default my back yard
yep im still working on it I call the last pic. climb potato salad its loose and steep. so far the tuber is the only one to make it up the salad climb.
Old 07-30-2006, 11:30 PM   #7
nice and nice work as usual
Old 07-31-2006, 01:19 AM   #8
The black widow 2 looks great!
The original will be on the rocks again very soon
Del Monte is offline   Reply With Quote
Old 07-31-2006, 08:23 AM   #9
How come your not running any Coils on the your front Shocks?
run2jeepn is online now   Reply With Quote
Old 07-31-2006, 08:33 AM   #10
Default front
Its a little experiment I have the front end held down with a strap (fuel line ) so it still has some flex but wont droop and run a little stiffer in the rear so no tourque twist so far its working great .
