Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: new tlt
Old 07-10-2006, 08:52 PM   #1
Default new tlt
ok i got another tlt and my friend also broke my nylint today so i was thinking maybe i should just use the body on a tlt build and use the working axle as a transmission for my vmg, i just want another crawler for my friend to use...
murdock is offline   Reply With Quote
Old 07-10-2006, 09:10 PM   #2
yeah ive seen it done, i have a 1.18th though
Old 07-11-2006, 12:05 AM   #3
I used the nylint planetary gear set and axle gear in a transmission once.
I ran the planetary box to the axle gear, then to another gear (putting less strain on the nylint gear). It was slow, just about right for me, but the nylint planetary popped within 30 minutes of normal use.
Although, I had to squeeze in a bigger motor (280 I think) to get any kind of power out of it. Even with all the reduction, the nylint motor didn't have enough grunt to move 4 moabs.
My esc did get really hot too.
Zuki Tyler is offline   Reply With Quote
Old 07-11-2006, 09:51 AM   #4
thanks tyler, but i might just use the axle on a 1/20th scale truck, so not as much power will be expected
do you guys now of a link where some one has used the 1.18th body for a scaler but didnt have to chop up the body to make a pede trans fit ?
i searched there is just so many nylint threads
