| | #1 |
| I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
| Ive seen this lil truck in action and am very impressed to say the least. a bolt on design of this truck is being tested as I write this for DoubleDub the design uses a true single stick design with pede tranny, outrunner brushless motor, tlt axles revo shafts, no shocks, no torsion chassis, but one leaf spring???????? the performance of the truck is amazing. It is being designed to use any tranny and or axle configuration (except for clod of course) We should have it available by the first of August body off shots later |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Jun 2006 Location: BUILDING A CSC-1 in south mississippi
| that a is way outside the box design, i cant wait to see how it uses one leaf spring. |
| | #3 |
| Rock Crawler Join Date: Sep 2005 Location: wyckoff, NJ
| i cant wait for a body off shot |
| | #4 |
| RCC Addict Join Date: Jul 2005 Location: Provo
| hmmm so its basically just instead of c channel its a peice of thin steel strap:-P please tell me i just tore tlt apart to do torsion but if this is better! |
| | #5 |
| OCCUPY RCC! ![]() Join Date: Dec 2005 Location: I am the 53%.
| A single leaf, were have I seen that??? Need some body off shots! |
| | #6 |
| Pebble Pounder Join Date: Feb 2005 Location: I am Dave!
| IT is a carbon fiber leaf spring under the tranny and a carbon fiber tube from axle to axle and supporting the tranny from above, I have been running this chassis for several weeks now trying different set ups on the spring rates and this version is awesome compared to any other tlt that I have run before,no links no shocks it's way too light,the first version was barely 4lbs, so I have been playing with weight and obviously tires and wheels.Hopefully we will get a vid up soon. |
| | #7 | |
| | #8 |
| I wanna be Dave Join Date: Jan 2006 Location: Henderson/Las Vegas, NV
| hey im gonna be in flastaff this weekend... im jus starting my tlt build im using an sw2 nothing crazy like you guys... awesome work, truely impressive... |
| | #9 |
| Well actually, I have. It was on a TLT torsion of a different design (not CF) and it looked and worked very well. There are many torsion design in the works at the moment. Can't wait to see your design. And lighter is better. My XRC w/o lead in the wheels was 4lbs. It's a "traditional" design w/ a chassis and links, and shocks and everything 4lbs 1oz.! |
| | #10 | |
| | #11 | |
| TEAM MODERATOR ![]() Join Date: Jul 2004 Location: Chit Chat
Burn. | |
| | #12 | |
| | #13 |
| I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
| Enough talk lets see pics. Sounds like a good design. |
| | #14 |
| Godlike ![]() Join Date: Jul 2005 Location: Central Coast
| What tires are those? Stock TXT's? |
| | #15 | |
Sorry, didn't mean to rain on your parade, but I have seen a link-less shock-less TLT chassis before. Apparently not the same as your, but you can see my point. So, lets see some pics of your design, it sounds cool. Last edited by dezfan; 07-12-2006 at 12:50 AM. | |
| | #16 | |
Double cut masher 2k as for pics gonna have to wait till after this weekend when the other SNAKE is finished. will have alum cages on both front and rear axles to carry the servos, bearings, and center chassis rod. also building one using juggy2/txt axles Last edited by rockwerks; 07-11-2006 at 10:07 PM. | |
| | #17 | |
PM me I will give you my cell # | |
| | #18 | |
That is not even close to what we are running now, miles away! a torsion design has many inherent problems one of which all the torsion forces are centered on several small screws in one spot on the axle. On the snake the loads are spread evenly across the entire surface and the center portion that connects the axles has bearing in the brackets so the center section can stay centered without need of arms or shocks and pics will be up after this weekends event. I will be running a juggy snake for the first time.......that is if I get everyone elses rigs done first! Last edited by rockwerks; 07-18-2006 at 05:59 PM. | |
| | #19 |
| hey man sorry i wasnt able to make it out there to meet you guys, but ill definetly be making a few triops to flagstaff in the future... |
| | #20 |
| Rock Crawler Join Date: May 2005 Location: In front of my comp
| Look's like a cool truck. |
| Thread Tools | |
| Display Modes | |
