| | #1 |
| Rock Stacker Join Date: May 2006 Location: Centerport
| I know on the Traxxas site it says that you can only run the aluminum idler gear with the delrin top gear but for crawling can you use the stock top gear thanks |
| Sponsored Links | |
| | #2 |
| 2006 2.2 National Champ ![]() Join Date: Dec 2004 Location: Driving my R/C rototiller
| Yeah, they work fine. Run them, if they fail upgrade when they do. |
| | #3 |
| Quarry Creeper ![]() Join Date: Nov 2005 Location: The Great White North
| The only reason they tell you not to use the stock top steel gear with the aluminum idler is supposedly that the two metal gears meshing together will cause radio interference. If you grease all the gears really well, this is virtually a non issue. |
| Thread Tools | |
| Display Modes | |
