Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: Widener and Maxx adapter?
Old 07-13-2006, 11:30 PM   #1
Default Widener and Maxx adapter?
Ok I have found one or the other but not a adapter that will do both for me. I would like to use maxx wheels but also have it a little wider. Any suggestion?
Thanks
Icebreaker88 is offline   Reply With Quote
Old 07-14-2006, 07:12 AM   #2
Thanks
How about using the Maxx adapter and then using offset wheels like RPM Stablemaxx or the Maximizer offset beadlocks? Of course, this is taking for granted you're not narrowing the wheels.
skellyo is offline   Reply With Quote
Old 07-20-2007, 11:37 AM   #3
jimbiss's Avatar
how about these: http://rc4wdstore.com/product_info.php?products_id=466
maxx is 17mm right?
jimbiss is offline   Reply With Quote
Old 07-20-2007, 11:03 PM   #4
Dream...Think...Create.
Nova's Ark's Avatar
Maxx size is 14mm. I can't find the wideners w/ adapters that I have on rc4wd. Mine are red aluminum and slide over the axle over the cross pin. Then the wheel goes on and the special long nut goes through and tightens to the axle. They work well, just be sure to use a small drop of blue locktite because they will loosen up on you while crawling.
Nova's Ark is offline   Reply With Quote
Old 07-20-2007, 11:29 PM   #5
Ace adapters. PM him, I think he still makes them.
Destroyer is offline   Reply With Quote
Old 07-21-2007, 06:49 AM   #6
Definitely recommend the ace adapters. High quality and not lightly to round out like plastic/delrin ones:-(
heavyD
heavyD is offline   Reply With Quote
