Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: Sticks are for beating children!?!?!?!
Old 07-16-2006, 10:59 AM   #1
Default Sticks are for beating children!?!?!?!
Well finally got to a point in the build were i thought i could show off some pictures.
Here are the specs:
Custom 1/8" styrene chassis
Losi trans
pede shafts
carbon links
hs-5245 steering servo
proline Ford corriour body
Feel free to leave some comments.
HVFracingwilly is offline   Reply With Quote
Old 07-16-2006, 11:22 AM   #2
trost's Avatar
Default scale?
looks realy scale! mabe you should put this in the scale section? mods?
trost is offline   Reply With Quote
Old 07-16-2006, 11:22 AM   #3
Wives not children.
FrankyRizzo is offline   Reply With Quote
Old 07-16-2006, 11:55 AM   #4
I thought about making it a scale truck but i feel that the body and tire selection alone do not make a scale truck chassis design and suspension systems make for a scale truck. the truck will be getting 2.2 moabs so if you know anyone looking for these bfgs let me know.
Old 07-16-2006, 12:42 PM   #5
How much for the set?
Crawlerguy851 is offline   Reply With Quote
Old 07-16-2006, 01:46 PM   #6
but rember the rule of thumb, the stick can be no larger then your thumb i like it. looks cool, good idea on the chassis. lets see some paint on that body!
Bknight is offline   Reply With Quote
Old 07-16-2006, 02:29 PM   #7
It's the stick can't be bigger around than your thumb. A toothpick is about the length of your thumb, that won't do much damage.
Good to see something different. Seems like every post is another stick these days. But since I haven't got my TLT yet, I can't say too much.
Jamus is offline   Reply With Quote
Old 07-16-2006, 09:26 PM   #8
Get off my lawn!
microgoat's Avatar
Don't know about that styrene chassis. Without lots of bracing, it's not going to take the loads from the shocks very well. You'll have a lot of torsional loading as well, and styrene likes to crack under stress.
You can avoid most of the flex by adding a brace at 90 degrees to the edges (think folded paper, much stiffer than unfolded) or even doing a box section. Either way, I think you'll want to tie the ends of the chassis together somehow to avoid pretzeling it.
Props for originality, though
microgoat is offline   Reply With Quote
Old 07-16-2006, 09:58 PM   #9
THanks for the ideas goat this is mainly a mockup/layout chassis I will be running this way to test the setup and the most likely have it cut from carbon fiber.
Old 07-17-2006, 06:21 PM   #10
SNAP!
Carbon fiber would be better
CustomCrawler is offline   Reply With Quote
