Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: Stealth tranny?
Old 07-20-2006, 04:58 PM   #1
Default Stealth tranny?
Was wondering if this is the right stealth tranny that some ppl swap into there TLT.
Icebreaker88 is offline   Reply With Quote
Old 07-20-2006, 05:04 PM   #2
TLTCrawlin's Avatar
looks like a nitro rc10gt one, I see a brake pad, and that thing that goes above it hooks to a servo, and is the brake control arm, or w/e they call em!
TLTCrawlin is offline   Reply With Quote
Old 07-20-2006, 05:36 PM   #3
No thats the wrong one.You need a rc10t4 or rc10b4 tranny.The only thing you can use out of that tranny is the bearings ,outdrives and gear.
Bad_Habit is offline   Reply With Quote
Old 07-20-2006, 05:38 PM   #4
http://cgi.ebay.com/NEW-Team-Associa...QQcmdZViewItem
run2jeepn is online now   Reply With Quote
Old 07-20-2006, 05:39 PM   #5
This is the one you really want.
http://cgi.ebay.com/RC10-Stealth-tra...QQcmdZViewItem
Old 07-20-2006, 05:40 PM   #6
You can use it if you make you own motor plate.
Old 07-20-2006, 06:12 PM   #7
Thanks for the input
Old 07-20-2006, 07:30 PM   #8
I would probably just get a pede trans.
Bam Bam is offline   Reply With Quote
Old 07-20-2006, 07:37 PM   #9
I would use it and make a motor plate. then use a third channel for a brake servo so you could completely stop your rig when ever you want I just had an appifiny
supercrawlerfreak is offline   Reply With Quote
