| | #1 |
| ... Join Date: Sep 2005 Location: USA
| Well while waiting on some parts and other things. I made up another Chassis for my next Build. Well I got all this done in less then an hour. I'm calling it "Skinny" The chassis is only 4.5in wide. I will have to take couple inches out down the middle of the HPI Jeep Body. The was to make something more Rock Freindly but still look like a Jeep. It should make a Nice Tuber for Comps. With the right link and shock set up it will have a low COG also. Here are some pic's I should have it weld about the same time my other one gets welded. If you have any input lets hear it. Everything you see in the Pic is what I used to make my Chassis. A Vise, and Bolt cutters. Oh and the Chassis is made from 3/16th Solid Rod. |
| Sponsored Links | |
| | #2 |
| I wanna be Dave ![]() Join Date: Oct 2005 Location: Columbia TN
| why not use 3/16 brake line, much lighter, I'm not being an a$$ just asking, is solid more avalable to you??? Not meaning to take away from the great chassis you've got there. I really like it. |
| | #3 |
| RCC Addict Join Date: Jun 2006 Location: Nor Cal
| I think it's cheaper right? But besides that how do you plan on connecting the rods? welding or brazing? is there really that much of a difference between solid or tube in weight. oh yeah can you braze solid? Last but not least it looks cool. |
| | #4 |
| I use Solid for its strength and it's half the price. But you only talking a few dollars difference. I tested a Brazed tube joint agaist a solid mig welded joint. Guess which won. Sides to me Mig it easier and cheaper. Last edited by run2jeepn; 07-21-2006 at 09:06 PM. |
| | #5 |
| Ok $5.00 for brake line, $4.50 for solid. Man I need that can of Coke |
| | #6 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| A properly brazed joint should be much stronger than a welded joint. The failure that I have had was never at the joint- it was beside the joints. |
| | #7 |
| Everyone has there own way. I'm not saying one is better then tyhe other. I like the fact that I can throw mine 20 feet or stand on it without a worry. But if you build one out of 3/16 tube you have to have alot of braces. Which adds weight. Here are some better pic's. The axle in the front is stock width. The rear is the widened one. |
| | #8 |
| Alot of braces????? Were talking r/c cars here. If you can destroy a tube chassis of any kind than you are one hell of a balls to the wall driver. |
| | #9 |
| Here a pic as it sits inside the body. You can see how much I have to cut out down the center. |
| | #10 |
| I like it, very narrow! Schweet You posted while I was posting so you answered me before I asked?!? Last edited by Kamikaze; 07-21-2006 at 10:11 PM. |
| | #11 | |
| Quarry Creeper Join Date: Oct 2005 Location: Bryant, AR
| | #12 |
| I bought 44ft for 15 bucks. Enough to do at least 2 crawlers. Maybe 3.... |
| | #13 | |
| | #14 | |
Oh a tubed rig should be about half the weight of a solid rod rig. Thats another reason way I made this one Skinny. But I wanted it to still look like a Jeep Buggy. More of a 1:1 One Seat comp rig. It should turn out better cool. I hope. | |
| | #15 |
| body shops dont braze because of the slow speed and cost of filler material. The braze does not melt the material around it, but it grabs on very well and fills the gaps without affecting the strength of the steel. Welding melts the steel and weakens it around the weld. Both would work just fine for what we do, to each his own. I prefer brazing because I have a torch and no welder. If I had a welder I would probably weld- it is much quicker. |
| | #16 | |
| | #17 |
| RCC Addict Join Date: May 2006 Location: Aroostook county
| c'mon dude i wanna see some work on Ramrod, i just started a build to..it will be updated every day |
| | #18 |
| Rock Stacker Join Date: Jan 2005 Location: Upland
| mig is better if you braze you have the heat consitrated longer also resulting in weaker material and with a mig its cleaner faster and ijust like it more and sweet chassie i cant wait o get started on mine |
| | #19 |
| you do have the part heated longer, but the metal is only anneled at a higher temperature than would be reached during the use of a proper brazing tecnique, a temperature that with mig welding would be reached very quickly though only for a short duration but was reached none the less. The max temp is responsible for the anneling, not the duration. |
| | #20 |
| learn somthing new every day i do hate brazing parts that have to be close together because i usualy have the heat on a little to long and drop a joint |
| Thread Tools | |
| Display Modes | |
