Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Losi White Spring Question
Old 07-27-2006, 10:19 AM   #1
1*
rcr3fan29's Avatar
Default Losi White Spring Question
Based on Bender's advice, I ordered some "white Losi springs" for my SW2. My shocks are aluminum T/E-Maxx big bore shocks. The red springs that came with the shocks are way too stiff. Anyway, I searched Losi's site, came up with only one "white" spring, and ordered it. Here's how it was described: Front/Rear Springs, Soft, White (4): MLST (LOSBO955). They came yesterday and I was surprised to see they were a good 3/4" or more shorter than the red maxx springs. No problem, I just slap on some of the plastic collar/spacers to take up the slack. I fill the shocks with 10wt oil (Bender recommendation).
I compressed the shock and was surprised when the springs wouldn't even return the piston to its normal position. Did I order the springs Bender referred to in his post? I looked at the pic of his "current" setup and couldn't tell if his Losi white springs were as short as mine. Does Losi make another white spring? If so, I'd appreciate any info on where to buy them.
rcr3fan29 is offline   Reply With Quote
Old 07-27-2006, 10:23 AM   #2
the losi whites that I run are the same length as the traxxas reds.
DirkDigler is offline   Reply With Quote
Old 07-27-2006, 10:43 AM   #3
Diggin' the new SCX10 II!
badger's Avatar
Those Losi white springs you have are discontinued.
badger is offline   Reply With Quote
Old 07-27-2006, 11:34 AM   #4
From what you described, it sounds like you got the springs for a Mini LST. No way they would be strong enough to hold up a 1/10 scale truck.
K_Willis is offline   Reply With Quote
Old 07-27-2006, 12:15 PM   #5
1*
rcr3fan29's Avatar
So what's an available substitute for the Losi whites?
Old 07-27-2006, 12:42 PM   #6
The springs you are looking for are part # LOSA5147. They are currently out of production, but the Horizon site lists them as being available again in September. A close substitution is the Losi yellow springs (part # LOSA514. They are in stock are are just slightly stiffer. I'm currently running the Losi yellows and find them too soft - way too sensitive to torque twist. I'm thinking of going back to the Traxxas red.
oIIIIIo is offline   Reply With Quote
Old 07-27-2006, 12:55 PM   #7
1*
rcr3fan29's Avatar
I ran down to my lhs and found some Associated "rear racing" springs. I bought 2 black springs (1.74#) and 2 green ones (1.9#). They fit over a maxx shock body at the lhs store so they should fit. I'll give them a try tonight.
Old 07-27-2006, 01:17 PM   #8
if you have a competition lhs near you they should have them
savageracer312 is offline   Reply With Quote
Old 07-27-2006, 01:53 PM   #9
Check with some of the guys at your lhs that race 1/10th scale buggy they might have a set they are willing to part with.
SW2Kid is offline   Reply With Quote
Old 07-27-2006, 05:01 PM   #10
i picked up the losu Yellow Springs , uses 22 1/2 wt oil and have had no problems
pro beater is offline   Reply With Quote
