07-28-2006, 10:59 AM | #1 |
Pebble Pounder Join Date: Feb 2006 Location: In a rock crawler down by the river
| Losi XXX Tranny
I'm building a TLT crawler and read these were as good as pede trannies only cheaper. Anyone recommend these? If so which model? Thanks |
07-28-2006, 11:15 AM | #2 | |
07-28-2006, 11:25 PM | #3 |
Rock Stacker Join Date: Jul 2006 Location: Lincoln
What about the old xxt tranny? I just so happen to have one of them laying around.
07-28-2006, 11:49 PM | #4 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
07-29-2006, 07:30 AM | #5 |
Rock Crawler Join Date: Feb 2006 Location: jacksonville beach
i just ordered two from unimoger, does any one have any tips on installing the pede sliders ? i tried to search it, every one that i found just went over the yokes for the dogbones...?
07-29-2006, 08:31 AM | #6 | |
yep thats the ticket, drill out to match the size of the dogbone drive then enlarge the slot on the drive to allow the set screw through, done | |
07-29-2006, 11:03 AM | #7 |
Rockwerks, I'm glad to hear that its a tough tranny. Now I just need to get ahold of a tlt and get started. I've been wondering what to do with that old xxt.
07-29-2006, 12:29 PM | #8 |
RCC Addict Join Date: Mar 2006 Location: Bedias, Texas
We've been running the Losi XX-T on ours for a while now and trying to break this machine. During R&D we broke a few things (even shafts) but the tranny still stands strong. The other night out running we pushed it so hard the locked diff actually started poping and we had to open it and do some shimming. After all of this the Losi still hasn't gave a bit.
07-29-2006, 02:04 PM | #9 |
Are the gears you have in that tranny still stock? If not what have you done to it? Anything special I need or should do to it? Thanks for any info.
07-29-2006, 10:21 PM | #10 | |
07-30-2006, 12:18 AM | #11 |
Thanks for the info insanerc. Guess I just need to get a tlt and get started.
07-30-2006, 02:01 AM | #12 | |
07-30-2006, 02:53 PM | #13 |
Pebble Pounder Join Date: Jan 2006 Location: Canada
07-30-2006, 05:29 PM | #14 | |
and no the yokes are part of the diff. they go into the tranny, unless its a very old XT then it will come with the one pictured here | |
07-30-2006, 06:58 PM | #15 | |
The molded outdrives pictured above are for a Losi XX-T. A couple people here have stated they will also work with the XXX. I've got a set on backorder to give them a try so I can't confirm one way or the other until them come it. Quote:
07-30-2006, 09:48 PM | #16 |
^ that one looks pretty clean i might have to try that first... thanks for all the help and pics guys! |
07-31-2006, 09:25 PM | #17 |
That is some great info. Thanks
08-06-2006, 12:16 AM | #18 |
ehh drilling sucks !!! i tore both trans down today and one was really nice and clean but doesnt turn too easy and the other has no mounting holes on the outside and was pretty dirty on the inside, but it worked smooth, as i was trying to drill a hole through the cups it caught and snapped the cup in two, took one out of the other trans and snapped that one also... i guess ill try the molded out drive set... but if they are metal how do i get the cross pin in it ? Last edited by murdock; 08-08-2006 at 10:04 PM. |
09-03-2006, 10:07 PM | #19 |
Newbie Join Date: Aug 2006 Location: Salt Lake City
If you havn't purchased your molded outdrives yet, dont. They are plastic and dont hold up well under a heavy load. Try to mod something metal instead.
09-04-2006, 07:36 PM | #20 |
I forgot about replying to this thread. I did eventually pick up a set of the molded outdrives and I can confirm that they do in fact fit a XXX-T tranny perfectly. I have installed them in a XXX-T tranny but have not yet tried them under load. They do seem a little flimsy though at the u-joint ears. I suspect they will twist under heavy load. Besides, the holes for the u-joint are a bit bigger than the Traxxas yokes so you also have to buy a special Losi joint.
