12-31-2004, 09:59 AM | #1 |
Newbie Join Date: Dec 2004 Location: TN
| Help TLT not Responding?
Well after I run mine for two batteries worth in a row.... My rear servo starts twitching all the time its a Hitek 303 or 308 Plus my truck last night just didnt want to respond to reverse or forward... I have a Novak XRS like this http://www2.towerhobbies.com/cgi-bin...XGNG5&P=ML I feel it is just warm, but not hot to the touch. I am running a 15th pinion and a 83 or 87 spur I forget... |
12-31-2004, 10:05 AM | #2 |
Pebble Pounder Join Date: May 2004 Location: east coast
| Re: Help TLT not Responding?
i have the same esc but i have yet to run it my truck is still needing to have the steering set-up but im gonna do that today and ill tell you if mine messes up as well matt |
12-31-2004, 10:42 AM | #3 |
I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
I bet your two servos are taxing the ESC. Try running just the front servo and see if it still doesn't respond. Make sure your batteries are fully charged as well.
12-31-2004, 10:56 AM | #4 |
Plays... thanks but its not the batteries.... It must be the ESC.... Didnt start doing it till I added the wieght of the BB's so I am guess the Servo's are screaming for help... after running for a long time... Will do on the servo thing... Funny thing is though its just the rear that starts twitching the front is fine.... |
12-31-2004, 06:05 PM | #5 |
Quarry Creeper Join Date: May 2004
are you running your servos off the battery pack? if so you might want to consider running them off a seperate battery pack like in nitro powered cars. When you add a second servo some batteries have trouble powering everything. Are you using a 1500 pack? that what i was running when i added my rear servo and all i could get out of it was twitches and the occasional turn so i switched to a 4 AA pack and ive never had the problem before. They sell rechargable packs for this purpose but i just got a battery holder from radioshack and used the servo wires from a dead servo. If you do what plays_with_toys says and it works with one servo this is probably your problem. |
