08-13-2006, 02:15 PM | #1 |
Rock Stacker Join Date: Jul 2006 Location: The Sticks
| Opinions Wanted.
so i been playing with solid axle trucks recently and i need peoples opinions as to what to do with my tlt so far. im stretching it to fit under a hpi bronco body, so i used traxxas tmaxx tierods and the stock tlt shocks (for now) to handle the mock ups. any suggestions or tips on what i should do to get the most articulation out of my current setup? im not really into buying aftermarket chassis or anything, since im building a budget crawler Last edited by 1BadJeepBruiser; 08-16-2006 at 08:23 AM. |
08-13-2006, 02:30 PM | #2 |
RCC Addict Join Date: Jul 2004 Location: The other Crawler State
see the stickies at the top of this page (TLT) for building tips. , the hot set up is a torsion chassis and can be made real easy.
08-13-2006, 02:31 PM | #3 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
And CHEAP!
08-13-2006, 02:37 PM | #4 |
Ditch that stock belt drive tranny. And get a Losi xxx-t, Stealth B4, or a Pede tranny to replace it. All those can work with the stock Chassis plates. Run some Maxx or Revo shafts for your drive lines. You are going to need a longer links for that wheelbase on that body. Either make your own which is real simple. Or buy some. I really don't know what you have and don't have already or what kind of budget you have. For Budget stuff get Maxx Shocks, MOPED ESC, TQ3 and try to find a set of used 2.2 wheels and tires. Oh and you will need servo's too. The cheapest I have found new ones for are BMS-620 made by blue bird. You will need to run servo savers with them, but there only 15 bucks. So if you go just 2WS you maybe able to get it going battery and all for under 200.
08-13-2006, 02:45 PM | #5 |
i have the maxx shocks already and i have a novak xrs in my hpi rally that i intended to use. couple tq3's laying around, etc. im not really concerned with the eletronics right now since the truck isnt even in roller form yet i have plenty of aluminum rod around here for my goliath project, but i was wondering what the idea stretch is on the tlt-1 to get the most out of the suspension and to still look right under the body |
08-13-2006, 10:00 PM | #6 |
RCC Addict Join Date: May 2006 Location: Roseville
If you check out my Budget Bronco build here: First crawler - Stock chassis - Who needs expensive stuff... 56k beware you can see how I did the stock chassis with a Pede tranny. Works really well on a variety of surfaces and even has decent side hill capabilities. I was crawling at Half Moon Bay beach with it this weekend and only had a few tip-overs with it.
08-15-2006, 08:01 PM | #7 |
nice write up trikster, its helping me alot with my suspension layout. i got a quick question though, do you NEED springs for a crawler? it seems to flex alot better without them on the stock shocks
08-15-2006, 08:05 PM | #8 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
08-15-2006, 08:36 PM | #9 |
Newbie Join Date: Jul 2006 Location: LA,CA
springs like bender said or everything just gets mushy
08-15-2006, 08:36 PM | #10 |
ill proly use tmaxx shocks with the softest ones i can find then. the stock shocks are too limited for my tastes since they dont compress enough and theres no spring options
08-15-2006, 09:48 PM | #11 |
ok so i spent some time tweaking it and changing stuff and i ended up with this im off to a good start i think. just need to keep adjusting it till its right |
08-15-2006, 09:56 PM | #12 |
Quarry Creeper Join Date: Feb 2005 Location: Grand Forks
what do u want to do with this truck? if u get a stealth, i could show u what i did to make an unbeleiveably good chassis using the stock chassis. |
08-15-2006, 09:59 PM | #13 |
whats a stealth?
08-15-2006, 10:29 PM | #14 |
yeah, i looked about 10 seconds after posting. thanks for the useless tip. anyway, a stealth isnt what im interested in. im gonna run a stampede tranny eventually once i get sick of the stock tranny slipping |
08-15-2006, 11:11 PM | #15 |
Heres what I did to my Stock TLT Chassis...
08-15-2006, 11:15 PM | #16 | |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
08-15-2006, 11:24 PM | #17 |
RCC Addict Join Date: Jul 2005 Location: Provo
here is my stock modified tlt chassis for a tranny i used a traxxas stampede tranny |
08-15-2006, 11:30 PM | #18 |
I think you are off to a good start.
08-15-2006, 11:33 PM | #19 |
RCC Addict Join Date: Feb 2005 Location: Crawlifornia Uber Alles
i like how you are using the stock chassis. you might want to use shorter upper links, just enough to make your axles level. this will keep your steering managable. also, you might want to ditch the front/rear bumpers. that will improve your approach angle. the stock TLT trans will bum you out, but you already said you are getting a stampede tranny anyways. i run the stock TLT shocks on my SW2 crawler. using longer ball ends, they are the same length as maxx shocks. work great on my rig.
08-16-2006, 02:17 AM | #20 |
ok i think i found what i wanted for my suspension. what i did was add a few holes along the extensions on the chassis plates and attached my shocks. they compress and move up perfectly. for the 4 links i have the same mounts as in my 2nd set of pics, only i have them coming together at the middle hole near the tranny. might be a lil too soft, as in the truck is gonna sag fully weighted, so ill have to see. might need to use spacers on the springs or switch over to tmaxx shocks. im quite pleased though since my driveshaft will bolt up perfectly, theres no side to side play in the axle, and it articulates alot before it binds. shes look good now |
