08-15-2006, 04:07 PM | #1 |
Quarry Creeper Join Date: Dec 2005 Location: San Antonio
| Team Comp Pro Rig... -body- 72 chevy c10 narrowed front and back -chassis- stock tlt modified for laydown trans -ESC- teaser 15t -Motor- 55t lathe -Servo(s)- hitec hs-645mg -Trans- pede locked -Axles- tlt locked -Tires- mashers 2k w/ spare swamp dawg -WB- lil under 14" -Overall Width- front- 10.75" rear- 10.75" -Diff clearance- 1.5" -Center Chassis clearance- 3" -Overall height w/ body- 8.5" -driveshafts- tmaxx -worst thing- no front dig yet so let me know what yall think, what i can do to in prove it, and feel free to post up your rigs... Last edited by D.I.L.L.I.G.A.F.; 08-15-2006 at 04:29 PM. |
08-15-2006, 04:26 PM | #2 |
Rock Crawler Join Date: Nov 2005 Location: Fremont/Newark, California
looks great.....
08-15-2006, 04:43 PM | #3 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
That looks really nice. I love the pinched body, I've done a Bronco but that makes me want to do a c10. 1 question, If it's a comp rig why the 14" wheelbase or are you guys running a 14 class? |
08-15-2006, 04:47 PM | #4 |
Ultimate RC Decals Join Date: Aug 2005 Location: San Antonio
that came out real nice.. almost too nice, you ready for the new crawl spot? need to take it out and bang it up a bit. |
08-15-2006, 05:00 PM | #5 | |
i'll try to answer this one.. if we ever had a comp (we haven't yet because there's only three of us that get together) i don't think we'll limit the wheelbase just the tire size. not sure about dilligaf but i set up mine to 13.5 just to improve approach and departure angles (90*). i know it's not the same but that helps out alot with the 1:1's | |
08-15-2006, 05:25 PM | #6 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
that only works if you hve chassis and body hanging out past the tires. not needed for a 2.2, matter of fact unless you are crawling over long smooth rocks, the shorter 12.5" wheel base will be very benificial. Its called BOA (break over anngle) the point at which the center of the chassis just touches an obstacle.based on tire height and ground clearance at CL of chassis a 12.5" wheel base rig at 3" of ground clearance has the same BOA as a 14" wheelbase rig at nearly 4", assuming you use the same tires on each rig. | |
08-15-2006, 05:26 PM | #7 |
looks awesome ! I just bought another tlt chassis. Hopefully I'll start meeting up with ya sa guys. |
08-15-2006, 05:30 PM | #8 |
which wb do yall think is better 13.5 or 14 ?
08-15-2006, 05:31 PM | #9 | |
08-15-2006, 05:39 PM | #10 | |
08-15-2006, 05:58 PM | #11 | |
08-15-2006, 06:10 PM | #12 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
Nice rig,I take it the spare is just a static display?
08-15-2006, 06:19 PM | #13 | |
i can see what you mean about the BOA and 12.5 is best in that situation. with a low sitting body i like to have the front tires sticking out past the body a bit so it doesn't get hung up on climbs. one thing about the longer wheelbase is mine turns like a bus. rear steer or front dig would help me out a bunch. (or a shorter wheelbase :-P ) | |
08-15-2006, 06:43 PM | #14 | |
neither does climbing.....its going over the top that you get hung up on, that a 12.5 would easily walk over. | |
08-15-2006, 06:56 PM | #15 | |
08-15-2006, 07:04 PM | #16 | |
i think you and i are talking about two different things. i'm talking about the length of the rig not width. anyways i think we hijacked d.i.l.l.i.g.a.f.'s post enough. | |
