08-18-2006, 04:30 PM | #1 |
Quarry Creeper Join Date: Jun 2006 Location: Carrollton
| SW2 chassis Qs
I bought the SW2 chassis alone without the upper mounts. What's the best way to mount my 96mm and 108mm links without using benders custom upper mount?
08-18-2006, 06:49 PM | #2 |
08-21-2006, 07:19 PM | #3 |
| Using the 96mm links as lowers and at a little over 12" WB. I still need a good way to mount the uppers. I need to know how high to mount them above the axle line. On Axle end how much separation do I need? |
08-21-2006, 07:30 PM | #4 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Try to find some angle aluminum stock, and make your own. Here's how my link set-up looks. |
08-21-2006, 07:39 PM | #5 |
What size angle aluminum are you running? Thanks again Bender, sick Chassis.
08-23-2006, 08:06 PM | #6 |
How dose this rear look? Still need to trim down the upper bracket. I also fixed the DS angle by pointing the pinion up(will only work on rear axle). Can't really flex it out since the upper bracket comes in contact with the frame(will fix that trimming down the bracket) . Using stock uppers for top links and 98mm for lowers |
08-23-2006, 08:09 PM | #7 |
nevermind, looks like I need to bring the uppers down about an 1". hahahah it's getting close.
08-23-2006, 08:13 PM | #8 |
RCC Addict Join Date: May 2006 Location: Aroostook county
Pretty cool lookin rig dude:-P
08-23-2006, 09:40 PM | #9 |
Thanks
08-23-2006, 11:09 PM | #10 | |
08-24-2006, 10:35 AM | #11 |
Pebble Pounder Join Date: Jun 2006 Location: Albuquerque
wow.. that thing looks horrid.. you should look closer at the photos Bender has posted in the past
08-24-2006, 11:19 AM | #12 |
Pebble Pounder Join Date: Aug 2006 Location: Oregon City
where did you get that baja body? sweet!!!!!!!!!
08-24-2006, 09:30 PM | #13 |
Okay, let's see if this looks better. Bender, I see what you mean about the spacers for the pede. The pass side upper link hits the DS. I'll move the spacers to the correct place over the weekend. The bug body was bought at a local hobby shop. Last edited by Ace138; 08-24-2006 at 09:33 PM. |
08-24-2006, 09:45 PM | #14 |
That looks alot better. Now you can trim the access material off the top of the mount. That should eliminate it hitting the end of the chassis.
08-24-2006, 09:50 PM | #15 |
Looking good ace! When will it be ready to head out to the lake?? Labor day weekend?
08-24-2006, 09:57 PM | #16 |
J.H, I should have it up by then, knock on wood. Bender thanks for your help. That bracket has a date with my cut off wheel and grinding disk. |
08-25-2006, 09:31 PM | #17 | |
08-27-2006, 08:40 AM | #18 |
Thanks Bender, rig works great. J.H I'm ready to break in the new mods out at grapevine lake. Let me know when you want to head out. |
08-27-2006, 04:02 PM | #19 |
Pebble Pounder Join Date: Aug 2006 Location: port angeles
| tlt kit and a chassis
im a noob at this i was just geting into this 1st time but i know alot about rc cars just new at crawling i wanna get the tlt kit wut chassis should i get thet well work with the tlt kit |
08-27-2006, 05:01 PM | #20 |
I'm a newbie myself but here is what I would do. 1. Buy TLT 1 Kit 2. Buy 55 turn lathe - http://rc4less.safeshopper.com/43/165.htm?105 3. Buy a 2 channel radio http://www2.towerhobbies.com/cgi-bin...I=LXASX2**&P=7 4. Buy 98MM Traxxas turnbuckles 5. Buy 2.2 rims (with hexs) / 2.2 Moabs or 2k Mashers 6. Buy a Sw2 chassis www.bendercustoms.com 7. Buy a Pede tranny from http://www.rccrawler.com/forum/showthread.php?t=23673 (when you order the tranny tell them what you are building they will make sure get the correct Spur gear and sliders) 8. Buy a hi torque servo 9. Use the search on rccrawler Good luck |
