01-14-2005, 03:20 PM | #1 |
RCC Addict Join Date: Dec 2004 Location: HELL.....
| tlt rear steer parts?
anyone know the part #'s i need for the rear steer? or possibly have the stuff that they dont plan on using?
01-14-2005, 03:46 PM | #2 |
Newbie Join Date: Jan 2005
| Re: tlt rear steer parts?
What are you trying to make into an AWS crawler? If it is a TLT-1 all you need is another servo. If you have Airtronics or HiTec buy a Futaba or vise-versa. I use a Futaba on the rear (its slower) and a BB Hitec on the front. You can solder the leads togather and there you go. I would sugest using an extrenal battery pack on the RX. That will/should give you a little extra power.
01-14-2005, 04:11 PM | #3 |
Quarry Creeper Join Date: May 2004
i would not use the rear steer parts that the book tells you to use because it is inefficient. The truck comes with all the parts to set up both axles the same way. If you do it like the book says then the back end has a weird ball end that doesnt work well.
01-14-2005, 07:55 PM | #4 |
well really the only part i would need is the female ball i can fab the other stuff really |
