01-18-2005, 03:52 PM | #1 |
RCC Addict Join Date: Jan 2005 Location: Green River Kentucky
| TLT axles
I am building a tsc 10 and was just wondering how strong the tlt axles are if they will hold up to 2.2 swamp dogs and 55 turn lathe with the tsc 10 wheelbase.
01-18-2005, 04:37 PM | #2 |
Rock Crawler Join Date: Sep 2004 Location: eureka
| Re: TLT axles
they are prettey tough. they will not usually break unless you are unlucky or you run maxx sized tires on it. then it can break the axel shafts at the end where they are not as thick , right before the dogbone endpiece. other than that they will most likely not break |
01-18-2005, 04:47 PM | #3 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
| Re: TLT axles 8O That was with the lathe motor and swamp dawgs, it was more poor driving than anything. I don't think you'll ever break anything |
01-18-2005, 05:11 PM | #4 |
I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
| Re: TLT axles
That right there is the most common part to break. If you order new ones, they send you the beefier Max climber versions though.
01-18-2005, 05:24 PM | #5 |
Rock Crawler Join Date: Aug 2004 Location: Concord Ca
| Re: TLT axles
" This is kickback on randysbbys screen name" Hey is that black electric tape holding the revo shafts on the alxe. I' seen my friends kid broke theright front and the left rear at the same time 8O 8O. |
01-19-2005, 02:07 PM | #6 | |
Newbie Join Date: Jan 2005
| Re: TLT axles Quote:
01-19-2005, 02:16 PM | #7 |
| Re: TLT axles
Tetsulo on RCMT replaced his when he broke his and the replacement that was sent was beefier than the stock one, and since the max climber is the newest truck, I'd imagine they're in those axles.
01-19-2005, 03:12 PM | #8 |
Quarry Creeper Join Date: Aug 2004
| Re: TLT axles
the hill climber A/B shafts ar thicker at the ball end of the shaft and are little longer to fit more secure in the axles stub.
01-19-2005, 08:05 PM | #9 |
| Re: TLT axles
Interesting, I have a max climber but I dont have a rock buster to compare it to, does anyone have a picture of the axle shafts in a rock buster? Thanks
01-19-2005, 11:11 PM | #10 |
I wanna be Dave Join Date: Mar 2004 Location: The Haunted Forest
| Re: TLT axles
for what it's worth, I run 8 TLT axles on various trucks and have yet to break a part on any of them! (I drive the *&^%! out of them too) ryan |
01-19-2005, 11:57 PM | #11 | |
i have snaped two ball ends. one doing cyclones on concrete with narrowed stock tires, and the secounds doing hill climbs from wet loose dirt to dry rock 8O whoops... | |
