10-07-2006, 11:46 PM | #1 |
Pebble Pounder Join Date: Mar 2006 Location: A former planet called Pluto
| Bronkomania!!!
Heres my first TLT Build up!! I just started with this body. and my custom chasis.. but still in progress in fact my chasis is very simple. but I am having a little problems with my driveshafts, the angle is too far inclined. but I am building double yokes... I think it will work Last edited by JeeperoManiako; 10-07-2006 at 11:52 PM. |
10-08-2006, 12:15 AM | #2 |
You might want to try this first. Cut some of you out puts down on your tranny and drill out your driveshafts yokes. So they slide over you tranny out puts. That maybe enough to fix your angle. Also it looks like you can lower your tranny just a hair without giving up any ground clearance too. Here is a pic of the tranny and Revo Shafts Dez did for me. Last edited by run2jeepn; 10-08-2006 at 12:17 AM. |
10-08-2006, 08:10 AM | #3 |
Rock Crawler Join Date: Aug 2006 Location: On the trail
what's up hugo!!!!! keep up the good work!!! |
10-09-2006, 12:31 AM | #4 | |
| Hey RUn2jeep! Quote:
10-09-2006, 06:30 AM | #5 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
thats the ones i am using they work for me pretty good had to stretch the truck out to 13" wb though.
10-10-2006, 02:34 AM | #6 |
Quarry Creeper Join Date: Aug 2006 Location: So*Cal
think your tires have enough armor all on them?? kidding
10-11-2006, 12:43 PM | #7 |
| some shots!! |
10-11-2006, 12:44 PM | #8 |
| more |
10-11-2006, 12:45 PM | #9 |
| and more...
the suspension of this ring is kind of stiff on the front.. but the rear end works well... |
10-11-2006, 01:16 PM | #10 |
what's the deal with the rear shock setup? i thought the ideal setup was something like this // \\ and yours seem to be \\ \\ |
10-11-2006, 03:13 PM | #11 |
Rock Crawler Join Date: Nov 2005 Location: Okinawa, Japan
yeah, that does look preety out of wack.
10-11-2006, 04:52 PM | #12 |
that's originality!! lol |
10-11-2006, 10:46 PM | #13 |
Pebble Pounder Join Date: Aug 2006 Location: Suffolk
The angle of the shock has changed from it's normal position because the rear end is twised. If you look at the mounts they are the same side to side, they both lean in, and the shocks appear to be mounted on the axle in the same place on each side, so just they way it looks in the pic I'd say. If I'm wrong, you might consider working with only your good eye open...
10-13-2006, 11:52 PM | #14 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
so you said the front end is stiff?? try laying out the shocks more. so why are you using piggy backs?? just had them or the work better?
10-14-2006, 01:24 AM | #15 |
| this piggys sucks!!
I throw them out !!! I bought on Ebay for 3dls. I did not like them because those are like a rocks I put softer springs, and drained the oil and nothing... |
10-14-2006, 01:24 AM | #16 |
| more pics.. |
10-14-2006, 01:25 AM | #17 |
| last two...
I think that I am going to need a set of wideners... |
10-14-2006, 01:29 AM | #18 |
...I hope this weekend have some real action shoots!! |
10-20-2006, 11:43 AM | #19 | |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
10-23-2006, 08:30 AM | #20 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
Hmmm... I like this truck, once you get the shafts sorted, it'll be a nice blend of scale and performance. Good job on the chassis, it follows the contours of the body well. Cheers 8-) |
