10-22-2006, 10:21 PM | #1 |
I wanna be Dave Join Date: Sep 2004
| High Clearence Links
are they worth it ? i notice on my jefferson chassis with savage lower links i get hung up on them often. i was thinking of ordering the delrin ones but i would like to hear some of your oppinions. i was thinking of making some out of aluminum but im thinking the delrin will slide better. |
10-22-2006, 10:34 PM | #2 |
RCC Addict Join Date: Apr 2005 Location: Seattle
I have been wondering the same thing, I hope we get some good answers...
10-22-2006, 10:44 PM | #3 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Delrin links will definitely be better, especially HC links. They slide over the rocks alot better then aluminum. Your driveshafts will take alot more abuse though, with HC links. So make sure they're up to it. |
10-22-2006, 11:14 PM | #4 |
im running the typical pede shafts.is there only one source for the delrin links ?
10-22-2006, 11:43 PM | #5 |
Mine are Revo, I can beat the crap outta them!
10-23-2006, 12:36 AM | #6 |
I've got two rigs; one with HC delrin links and the other with straight alloy links. And there is a very noticable difference between the two. And I think I'd disagree on how much punishment the pinion yoke takes. I don't think it's any worse than straight links. If both tires crest an obstacle at a lower point than the middle of the axle does, the pinion is gonna take a hit no matter if you run bent links or not. But the HC links won't drag like the straight links do. I think driveshaft punishment is gonna depend on the angle of the driveshafts and the diameter of the tire. If the pinion yoke sticks out farther than the radius of the tire, it's gonna be more vulnerable to the rocks. Does this make sense or do I just sound like I'm talking outta my ***? Or is this just obvious to everyone already? This may also be obvious to others, but I run the female end of the driveshaft on the axle because the if you run the male side, the lip on the yoke catches on EVERYTHING. I also can't think of any other source for pre-made delrin links other than Xtreme RC or Double J. |
10-23-2006, 12:47 AM | #7 |
RCC Addict Join Date: Mar 2006 Location: Bedias, Texas
Hello, I hate to pimp my stuff here but we carry straight and high clearance links as well as 2 different materials, 3 different sizes, 2 different sizes of all thread insets, two different sizes of rod ends, and coming very soon a large selection of link colors. What Bender said is very true. The HC links are great but you should have a strong drive shaft. I highly recommend Revo shaft, absolutely huge! Another way to protect your driveshaft, run HC links and have a world of clearance in the very near future may be to clock your axle with adjustable C-Hubs. Look for an update this week!!! David Xtreme Rc Hobbies Last edited by insanerc; 10-23-2006 at 12:50 AM. |
10-23-2006, 03:32 AM | #8 |
insanerc, I should've ordered them when I ordered my axle ends the other day! Oh well... How do I order a specific length thickest diameter black delrin bent set? |
10-23-2006, 06:07 AM | #9 | |
You can just go to our web site and pick out what you want there. If you don't see it just email or pm me here with what you would like and I'll give you a price. We help people out with link details all of the time. It's not a bother to us at all, it's our business. Sincerely, David Xtreme Rc Hobbies | |
10-23-2006, 07:55 AM | #10 | |
10-23-2006, 07:35 PM | #11 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
I have been running HC rear links (bent revo red pushrods) for months and i wont ever go back to straight rear links. It allows me to get further up an obstacle without getting hung up. It also helps on breakovers a little. Sure the shaft gets a little beat, but it hasnt casued any strength issues whatsover, probably since i run steel yokes, and the pinion is pointed up at the trans output. I havent tried front HC links yet and im not sure there will be a large benefit since they are shorter than the rears in my application, plus, the front pinion is alot lower, which will negate most of the advantage. |
10-23-2006, 08:16 PM | #12 |
Rock Crawler Join Date: Jul 2005 Location: Central Coast
Sort of a noob question here, but is there a certain formula for making high clearance links? |
10-23-2006, 09:37 PM | #13 |
formula ? or process ? im sure there is. a template is proly used and some heat for the delrin links.
10-24-2006, 03:33 PM | #14 | |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
10-24-2006, 03:34 PM | #15 |
Anyone willing to tell me how to calculate the right lengths? |
10-24-2006, 03:42 PM | #16 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
10-24-2006, 04:16 PM | #17 | |
OR make it 1/2" or a 1/4" to long bend until you like it. Or Just do it and come out build at the WB it has on it as is. Basically you can play with different ways to do it. | |
10-24-2006, 04:51 PM | #18 |
HC links rock. When I competed in moab my sw2 didnt pass inspection, 1/4" too long, solution: bend the rear links I had to make a few adjustments to get the ride height back where I wanted it but since then I have not messed with them. They work great As a side note I did change the pinion angle on the rear so the yokes angle with respect to the ground matches the links. Bender is right they take way more abuse with HC links. |
10-24-2006, 05:02 PM | #19 |
Another way is to build a simple jig from wood, position your chassis and axles, then you can get exact measurement and make sure that you don't end up with you caster way off. Here's a pic of how easy it is, wheelbase was set, axles squared, set at 0 degrees caster, links measured and installed. David |
10-24-2006, 05:07 PM | #20 | |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
Bender made me some HC Delrin links for my new comp rig and I love them. Very beefy and as smooth as my shaved ***. | |
