Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: what is this thing?
Old 11-08-2006, 12:38 AM   #1
Default what is this thing?
wow i've seen this kind of thing a few times and I think its pretty amazing. I'm sure ya'll have seen it and know what its called. How does it perform? its so simple I want to do one on my tlt rig. does it get as good of flex as the conventional 4 link setup?
srfrkyle1234 is offline   Reply With Quote
Old 11-08-2006, 12:41 AM   #2
2006 2.2 National Champ
BENDER's Avatar
That's a 3 link set-up, basically. I've never tried it myself, but other members have done it.
BENDER is offline   Reply With Quote
Old 11-08-2006, 03:17 AM   #3
3 link w/wishbone upper works good, good flex, no side to side "swing" like a 4 link. Just a tad bit easier to set up than a 4 link as well.
Geargrinder65 is offline   Reply With Quote
Old 11-08-2006, 04:53 AM   #4
Colt Python/SR9c
TwistedCreations's Avatar
its a 3 link as mentioned.... It basically is the same as a 4 link. Instead of mounting 2 upper links, it's only one. If you look at the upper wishbone,both sides invert towards teh center, so that takes care of your triangulation so you will not get any side to side..
TwistedCreations is offline   Reply With Quote
Old 11-08-2006, 05:26 AM   #5
I think 3 links are harder to make. Thats just me though. You have to have that upper link bent right. Then figure and way to dill a hole or braze/Weld and Heim joint on it. Have to get centered also. 4 Links are more adjustable and easier to fix mistakes. On a 3 link you almost have to start all over.
Old 11-08-2006, 07:42 AM   #6
Moderator Rule Breaker
eric113's Avatar
I'am running a 3 link and love it! If you bolt your rod end on, The hardest part would be making sure it straight and sqaure.
eric113 is offline   Reply With Quote
Old 11-08-2006, 10:20 AM   #7
Oppan Gangnam Style
chino63's Avatar
i have been running a 3-link on my bronco front and rear since i built it. works great, just using maxx lower a-arms.
chino63 is offline   Reply With Quote
Old 11-08-2006, 10:56 AM   #8
cool thanks for all of the feedback. I thought it looked like a really neat idea as an alternative to a conventional 4 link setup. I have a small tube bender so I may just try this and see how it works. thanks again for all of the information.
