11-14-2006, 06:55 PM | #1 |
Newbie Join Date: Oct 2006 Location: scranton
| newb question about links |
11-14-2006, 07:24 PM | #2 |
Traxxas rod ends have a bit more play.
11-14-2006, 07:24 PM | #3 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
That's a pretty extreme angle for any rod end. So far, I found Jato rod ends have the most movement. They're pretty beefy too. http://www2.towerhobbies.com/cgi-bin...?&I=LXKMD6&P=7 |
11-14-2006, 07:39 PM | #4 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
You're going to have binding issues if your links are at that extreme of an angle. Traxxas or Dubro standard ends have a good amount of flex to them. You'll want to use conical washers to help get as much flex as you can though.
11-14-2006, 07:57 PM | #5 |
i could probably make some standoff brackets to cut down on the angle. thanks for the quick reply.
11-15-2006, 01:02 AM | #6 | |
11-15-2006, 09:38 AM | #7 |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
You could also make a V that comes down to 1 point, then just link that one point.
11-15-2006, 11:12 AM | #8 |
Pebble Pounder Join Date: Sep 2006 Location: Medford Oregon
I did some links like that, I just bent the end of the links to help straten out the angles @ the ball link. It worked out well, but it's not eazy keeping the bend right at the end of the link while U are bending it:-P
11-15-2006, 01:46 PM | #9 |
that was my next thought bending them the same would be hard hough. ill see what i come up with tonight.
11-26-2006, 01:31 PM | #10 |
11-26-2006, 06:35 PM | #11 |
Newbie Join Date: Feb 2006 Location: West salem
Zip Ties are temporary??? Since when?
11-26-2006, 06:52 PM | #12 |
Pebble Pounder Join Date: Aug 2006 Location: Suffolk
That's a stout looking skid, is it plastic or bent sheetmetal? Looks like you got your links figured out pretty well, ended up close to the type of setup my TJ 1:1 has, works well full scale so I figure it'll probably work well for you too. You should post a buildup thread on your rig...
11-26-2006, 07:06 PM | #13 |
the skid is a peice of plastic from those collapseable road signs. dont ask should i stand the front shocks up some more or will torque twist not apply on the front shocks? dont worry im sure there will be some permanent zipties on there somewhere. and since this is my first build and i realy dont know what im doin just yet i didnt feel i should be making a writeup. but dont worry though its stages there will be pics. |
11-28-2006, 04:32 PM | #14 |
11-28-2006, 04:45 PM | #15 |
Rock Crawler Join Date: Sep 2006 Location: Esco.
Tubers are so much fun. Your front end looks a little like mine. Have fun.
